tcs solonoid/ relay 442
i thought this was for manual trans applications only.........until i saw ref about it for auto trans too in the service manual. i found the solonoid and bracket in one of my boxes and a note that it mounts to the pass side frnt carb bolt. but i also saw in the manual that there is a tcs relay on the firewall. i do not remember taking this off the firewall on teardown. whats the deal with this relay?????
charlie,,,,
charlie,,,,
'70 style TCS "switch" bracket mounts on a studded-end intake bolt...not on the carb anywhere. The stud/bolt is the forward most of the two middle intake bolts on the P side of the intake.
TCS switch mounts onto the bracket with a 1/4" coarse thread bolt.
All the other intake bolts on that car are the regular head style bolts.
[QUOTE=70Post;508259]'70 style TCS "switch" bracket mounts on a studded-end intake bolt...not on the carb anywhere. The stud/bolt is the forward most of the two middle intake bolts on the P side of the intake.
All the other intake bolts on that car are the regular head style bolts.[/QUOTE
thats excactly{sp} what i was looking for!!! not sure why i wrote it was on the carb for. do you happen to know wht the tcs relay on the firewall is for? thanks very much!
charlie,,,
charlie,,,
I am not sure if there is any relay associated with the TCS. There is a connector which is part of the engine harness which connects to the ignition and the transmission (AT)/shifter(MT) switch. If this is a 1970 application see page 6C19 of the Service Manual.
