Tapping valves
Old May 10, 2011 | 04:30 PM
mccoy88olds's Avatar
Tapping valves
Hello,I recently put a 350 olds engine in my 88 cutlass and the engine ran hot.So now my valves are tapping ,is this bad and is it fixable. Also my dad said my drive shaft is in the trans to far so its keeping the the engine from turning at its full speed and thats my reason for my engine over heating
Old May 10, 2011 | 04:55 PM
odie's Avatar
chances are you have warped valve stems due to excessive overheating,the larger problem being galling of cylinder walls @ piston rings have lost all tension thus will not seal compression. seizeing of piston to cylinder walls will not allow the engine to rev up eventually the engine will seize up . nothing short of complete overhaul ie boring of cylinders and replacing valves will fix the problem...
Old May 10, 2011 | 05:05 PM
Thanks odie so what im looking at is pretty costy huh,what do u think about the driveshaft issue, is what my dad saying true
pcard
May 23, 2014 10:35 AM
Mak
21
May 27, 2012 09:39 AM
thorpedo91
Nov 26, 2010 04:10 PM
hodgeman
Jan 23, 2007 10:15 AM
57teebyrd
Aug 30, 2006 07:44 PM
