Taking off the Grilles
Old Jul 27, 2009 | 11:03 PM
Southern_Hospitality's Avatar
Guys, I am trying to take off the Grilles so that I can have them painted. There were four bolts across the top that I took off and two behind the grille. I figured this would do the trick, but it's still bolted on some how. I need directions on how to take off the grille of a 71 Cutlass Supreme. Thx.
Old Jul 28, 2009 | 08:09 AM
wolfman98's Avatar
Captain of my ship
Question Stone shields?
Not sure about the 71 cutlass but on my 69-98 I had to unbolt the stoneshields from the grills.
Old Jul 28, 2009 | 08:03 PM
Attach points - Grille
They are very much like the 72 grilles, except they're metal instead of plastic. You got the 4 screws on the top, that's a start. If you get under the car with a flashlight, you should be able to see that the grills attach to tabs onto the stone shield. So that means that you're going to have to take the stone shield (middle plastic part that holds the grills) off so you can unbolt ALL the bolts that hold it in place. Take your time and don't bust anything. I scanned this pic from the 72 assembly manual. If it doesn't come through clear enough, send me a PM with your home email and I will send a larger pic.
lemoldsnut
Sep 4, 2014 11:36 AM
dartphil
19
Aug 7, 2011 05:13 PM
Wyze
Aug 26, 2010 01:54 PM
bigbrother
17
Jul 6, 2008 05:27 PM
silverriff
Mar 3, 2008 04:57 PM
