Steering wheel corrosion, replace horn button
Two issues today:
First, my 4-spoke steering wheel has several spots of corrosion, but otherwise is in good condition. How can I eliminate the rust without altering the finish or texture of the spokes?
Second, the clear plastic center of the horn button is cracked. Does anyone sell the clear plastic cover, or do I need to replace the whole assembly?
Also, how do I remove the trim ring, cover, and button?
thanks,
Rattlecan
thanks,
Rattlecan
the ctr cap just pulls off although a little rust can make it pull off hard, the ctr of cap is availible repro....just set the rubber part in warm water to to make it pliable and you can remove the old ctr and install the new one.
Swapping center caps isn't as easy as you'd think. The repro ones crack pretty easy.
I've got a horn with a cracked center, and I tried putting a new one in and it cracked too. :/
I gave up and never installed the sport wheel.
Trim parts reproduces the plastic center either 68/70 chrome edge or 71and newer silver edge.
RAMBOW
Jul 26, 2011 01:47 PM
ccchrome
Feb 13, 2010 03:30 PM
