Starfire project has begun!
Ok, took all of the interior out to take a look at the floors, The frame is ok but the floors need some help. Nothing terrible though, much better than I thought it would be. Mainly needs replacement right around the seat mounts. But this is my first step, fix the floor, coat it. after the floor is fixed and coated, on to the engine bay, get the engine bay sandblasted and coated, get the motor in it and get the car running so its at least able to move under its own power, and then on to body work. I already have the entire right side of the car done body wise, just needs freshened up, primed and painted. anyway enough of my ramblings, heres what I found.
Cody
Cody
Rear floor pans
Check these out. They are for Pontiac, but I believe they will work in an Olds.
https://secure.amesperf.com/qilan/Se...oor+pan&sort=0
Thanks for the info Charlie! the nice thing is with enough patience and some thinking i can make pretty much anything work but that's a great start, I certainly could alter those pans a little and weld them in.
oldspackrat
April 10th, 2014 04:08 AM
oldsdroptop
June 2nd, 2009 07:03 PM
