Standard duty or heavy duty flex plate for 350 engine?...
Old Feb 19, 2016 | 11:29 AM
tcolt's Avatar
As I'm building my 200-4R to go in the 1972 Vista Cruiser, I came across slightly worn teeth on the ring gear and starter. Since I will be keeping this car I only want to replace the gear this one time. Is the standard duty flex plate and gear prone to wear or should I upgrade to a heavy duty hardened gear? Does anybody have recommendations for where to buy and what the differences are in quality? I can get a standard duty flex plate for $40 from my local transmission supplier....
Thanks, Tom
Old Feb 19, 2016 | 11:37 AM
The outer ring is hardened on all flex plates. For normal applications the standard one works fine. Unless yours has major wear its probably still good.
Old Feb 19, 2016 | 11:40 AM
70cutty's Avatar
Beer Connoisseur
Just buy a standard one. On my 350 I think I had a pioneer brand, it was around $50-60 at Summit.
Old Feb 19, 2016 | 04:15 PM
tcolt's Avatar
Thanks guys. I didn't have any trouble engaging the starter, but it seems like a good time to do it with the transmission out. The starter gear actually looks pretty worn, so I'll probably swap that out too, although I don't know how much of a bevel it is supposed to have. I don't know if you can replace just the gear on these old American cars or only the whole starter.
Old Feb 19, 2016 | 04:38 PM
Post some close up pictures so we can see it or go down to the parts store and compare. I agree the cost is not much to replace, but I think the original parts are better made.
Old Feb 23, 2016 | 04:43 PM
tcolt's Avatar
Good idea Eric
Here are pictures of the starter and ring gears. The starter looks fairly worn. I don't think a new one would have quite that much of a bevel? Are these available new separately to put onto my starter ? The ring gear is only mildly worn, but enough where I thought I might as well do preventative maintenance.
Thanks, Tom
Old Feb 23, 2016 | 05:01 PM
Although they may have a few more miles left on them, I'd change both the flex plate and starter drive.
Old Feb 23, 2016 | 08:42 PM
tcolt's Avatar
Thanks Eric
Does one of these look like the part I should be looking for?
http://www.ebay.com/itm/New-Delco-St...hUFFR4&vxp=mtr
or
http://www.ebay.com/itm/New-Starter-...dWRKNn&vxp=mtr
Old Feb 23, 2016 | 08:55 PM
The first is definitely not it, the second says its not compatible. You can buy one at a NAPA store.
Old Feb 23, 2016 | 10:21 PM
64Rocket's Avatar
I'm with "Eric"on this one "Napa" auto parts is the place to go.
Gene
BlueCalais79
Jun 19, 2011 07:52 AM
wmachine
Oct 14, 2009 09:49 AM
64 Cutlass
Suspension & Handling
Sep 15, 2009 10:46 AM
snooter
Jan 25, 2009 07:20 PM
ROCKET JO
Dec 20, 2007 03:32 PM
