Springy thingy?
Old Aug 12, 2012 | 06:36 PM
ralsy's Avatar
Springy thingy?
What is this springy thingy in the back of my Rochester 4brl, and what does it do????????
Old Aug 12, 2012 | 06:40 PM
That's the hot idle compensator.
Under the cover is a bimetallic strip with a rubber end, which closes an air bleed hole that goes into the manifold.
When the engine gets hot (such as idling in traffic on a hot day) the strip deflects, opening the hole, and allowing in extra air to lean out the mixture to prevent an over-rich condition.
The spring there is a button you can use to hold the valve closed when tuning a hot engine, so as to make your settings accurate.
See your '68 Chassis Service Manual.
VI Cutty
Brakes/Hydraulic Systems
Jun 24, 2014 06:38 PM
GRIFFER
Jan 10, 2011 06:08 AM
auto_editor
Dec 14, 2010 09:26 AM
labrats804
May 30, 2007 08:30 AM
