Springs
Old May 12, 2010 | 08:21 PM
ELECMAN's Avatar
Springs
I want to get a set of front and rear springs for the car.I have a 72 cutlass supreme convert 455ci motor and ac.looking for moog springs dont know the difference between heavy duty,variable rate,constant weight.just want the car to sit a little above factory height and also have a nice ride. Anybody know the numbers to moog thanks
Old May 12, 2010 | 08:31 PM
olds455's Avatar
I just installed the moog 5374s in the front of my 70 cutlass. They're for a small block with a/c. I have a 455 with aluminum heads and a/c. It should sit well. Last year I rebuild the rear end and suspension and put in a moog set that raised the rear way up. The rear was original and would rub tires on some large bumps. I would have to look up the number if needed. I could also send or post some pics if needed. Joe
Old May 13, 2010 | 06:55 AM
AZ442's Avatar
I just remove MOOG 501's from the rear of my 70. they lifted the car 2" in the rear. I spoke to MOOG prior to the order and they advised me the 501 was the same height as stock. Not so much.
Old May 13, 2010 | 07:56 AM
Oldsmaniac's Avatar
Call Detroit Eaton Spring and they can supply anything you need just tell them what ya want.
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
1acesmith
Aug 11, 2011 11:03 AM
eddiem06
Dec 24, 2006 08:06 PM
gypsee
Brakes/Hydraulic Systems
Oct 20, 2006 07:18 PM
mcutlass1969
Aug 6, 2006 03:47 AM
