Split fire plugs
Split fire plugs
Tried to stop my friend from putting split fire plugs in his 68 olds. I told them they were junk, and that years ago the FTC sued them for false ads.
Any thoughts
Any thoughts
I remember them being sold over here.
The claim was that two sparks occurred simultaneously to different parts of the electrodes, ignoring the fact that electricity travels along the path of least resistance.
I was surprised that our advertising standards authority allowed this.
Roger.
Roger.
There's a good reason so many performance cars today come with 2 plugs per cylinder ... You get as much benefit from just clocking your plain jane plugs correctly as those split fire/quad/e3 plug can offer. If the split fires had any appreciable affect, the manufacturers would have been using them to fight off the EPA dogs.
I prefer just a standard plug. With the limited amount we drive our cars, in most cases, they will last along time. Occasionally I will check and regap just to keep everything in good operating condition.
I imagine there must be a reason, though I'm not sure what it is.
Back in the day I performed an experiment on the Splitfires. I had a set in my SBO 350. I noticed a 3 to 4 mpg increase over my traditional plug when the splits were new. I also tried a set in a 89 T-bird w/ fuel injection. There was no noticeable increase in mileage. However, I did have to have emissions checked on the T-bird annually. There was a slight improvement in emissions (lower measure numbers).
I can only attribute this to the flame kernel being more exposed due to the split ground. As a side note the overall acceptable performance of the splitfires were shorter than a traditional plug in my experience.
MDchanic- those Bosch +4 plugs do have four grounds but the current will only flow to one ground. The ground with the lowest ohm resistance is where the spark goes. I guess in theory four grounds means longer life? I don't know. I never owned a set of the Bosch +4's. I usually get NGK Iridium's for my modern vehicles, and NGK's for my Oldsmobile perform better than anything else I have tried.
http://www.mtfca.com/discus/messages/118802/131376.html
Snake oil spark plugs go way back. You can imagine what happens when the shaft wears out and breaks.
x2. I don't need a high mileage plug or one that will spark under any foul conditions - I keep my engine in better shape than that.
I bought a set of nitrode plugs for the heck of it, I will be putting them in this spring to see how they run, normally I run the ac-delco's.... but I read up on the nitrodes and figured I would give them a shot.
No experience with E3's I do remember one comment from a small engine repair guy. He told a customer if he ever brought his equipment in to the shop to be worked on and it had an E3 plug in it he would not allow the equipment in his shop.....
4-ever-olds
Nov 14, 2017 05:56 PM
bob p
Apr 10, 2015 01:55 PM
