Splash shield Rubber and clips
Old Feb 5, 2019 | 04:37 PM
brandon reynolds's Avatar
Does anyone know the exact type of rubber used on the splash shields that I could buy in sheet form? And also does anybody know where I can get these clips picture below in bulk like An AUVECO part number? Thanks
Old Feb 6, 2019 | 11:12 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Can't see the pic at work( very tall firewall). Are you looking for the A body upper control arm splash shields? If yes they are readily available cheap with the staples/fasteners. Most any GM A body resto part supplier carries them. The Vette suppliers carry both types of fasteners, push in plastic and SS staples, so should the A body suppliers.
Old Feb 6, 2019 | 05:24 PM
The clips I need are the metal spring loaded ones for 65
Old Feb 6, 2019 | 05:30 PM
Bfg's Avatar
Bfg
Fusick also sells the metal clips.
Old Feb 6, 2019 | 06:18 PM
Ahh, I see the pics now that Im home...you want the radiator to core support seals and fasteners for a 65. Not sure on the material or fastener specs for a 64-65s. I assume you've called Fusick, Year One, OPGI etc...???
Did you look at other GMs of the era...Buick Pontiac Chevelle? Most everything for a GTO/Chevelle/Camaro/Vette is reproduced.
You might find a seal which is larger say for an 88/98, Cadi, Eldo, Duce in a Quarter etc... and cut it down...
As mentioned in my previous post it could be used on Vettes, (the fasteners that is ). Corvette Central, Ecklers, Mid-America are just a few suppliers I use.
I do know the A-arm dust shields in an early C3(68 or 9) is the thinner material similar to the Olds core seals. You could order a set and cut straight strips from them...I do remember thinking to myself when I installed a set in my 68 C3 that the material reminded me of the core seal in my 68 442...just brainstorming.
Old Feb 6, 2019 | 06:27 PM
Yes fusick has them but they’re $1.50 apiece and I need 50 I was hoping to buy bulk somewhere thanks
Old Feb 7, 2019 | 09:07 AM
My442's Avatar
Steele sells the masticated rubber in sheets, or they did a few years ago when I bought some.
Old Feb 7, 2019 | 02:40 PM
Thank you I found the rubber I’m still looking for the clips though
Old Feb 10, 2019 | 10:59 AM
50! Thats how many a 65 has?
Try Herbs Fasteners.
https://hardwareandfasteningsolutions.com/
or
http://www.thefastenerwarehouse.com/home.html
tdhill01
Jul 2, 2019 01:42 PM
oldcutlass
Jan 5, 2018 09:26 AM
tinner
Jan 20, 2017 03:31 PM
Rocket331
Body work
Sep 18, 2012 04:00 PM
budsisto
May 19, 2011 02:50 AM
