Speedometer Reducer
From: 25 miles North of Tampa, Land O' Lakes, Florida (Originally from Bethpage, Long Island, NY)
Speedometer Reducer
Does anybody know if they make a 25% speedometer reducer for my 72 Cutlass? The only one I found is a 38% but that is too much. If so, can you direct me to the right place to locate one. Thank you in advance.
http://speedometersolutions.com/ They have or can build a reducer for you, or for much less, sell you the correct gear for your speedometer.
By speed reducer, do you mean a different speedometer gear that will turn 25% slower? If so, just pull the current gear out and count the teeth. What transmission are we talking about? It will make a difference in the speedo gear that used.
Go to this site to determine what gear you need.
http://www.tciauto.com/tc/speedometer-gear-calculator/
I am using a 40 tooth gear which means I would need 50 teeth to slow down speedo 25%if I'm correct. I don't think they make,a 50 tooth so I will need the reduction unit
