Speedo reset????
Speedo reset????
I do not remember seeing this discussed before. I am knee deep in the restoration of my 72 vert. I am thinking it would be good to start the clock all over again at 0 since this is a frame off. I remember back in the day it was illegal to tamper or alter the odometer on a car. Can you reset the odometer? How do you do it? I think the mileage on the car is acurate at 83000 mi showing but who knows. It could be 180 or 280. I just think it would be neat
to set the clock at 0 and start all over
Yes, you can reset the speedo. It involves taking the speedometer apart which is surprisingly easy. I took one apart at the boneyard this summer to see how it works. Not that complicated, just very tedious and work carefully. It took me about 20 minutes to take apart and put back together, but I wasn't striving for perfection. If you have the patience, it's very do-able.
You can send it out also for a complete rebuild. Bob's Speedometers does these restos which also includes putting new numbers on the odometer wheels. It will come back looking like new. Not cheap though.
Bob's Speedometer
Bob's Speedometer
It's been done a lot with people in similar situations. In most states these cars are mileage exempt meaning it does not matter. You can take the odometer apart and realign the digits or get a drill in the cable and let it run for a while.
It's only illegal if you claim the new mileage is the true mileage.
If you check the little box on the transfer documents that says "Odometer does not reflect true mileage" it's fine.
Yikes, Eric (the other Eric that is ) if you tried that it would put a LOT of wear on the speedo and would take a heck of a lot longer than a little while... besides, taking it apart is a necessary evil of the hobby. What I would do if this is an issue for learning is buy a couple of speedos cheap from 2blu442, jensenracing77 or oldspackrat and practice on them. I have one from a 1970 with a speedminder option that I have to take apart to restore so that's what peaked my curiosity at the boneyard this year. Not sure if I kept one of them or not, I have to check my inventory. That would make a cool thread topic though....
Ah, the "Other' other Eric ... Good point. I didn't consider that the car would ever be sold though....and I know Steve wouldn't do something underhanded like that.
Ah, the "Other' other Eric ... Good point. I didn't consider that the car would ever be sold though....and I know Steve wouldn't do something underhanded like that.[/QUOTE]
Good points by all. The only thing that I will ever point out on this car is that I "Did it my Way". It is not going to be original or correct but it will be very nice.. And Fun!
I have set multiple replacement mechanical odo's to reflect actual mileage on the originals.
Disassy is pretty easy. One key thing is to try not to handle the numbered wheels much as the numbering can come off easily. In the 80's, I think some parts were intentionally painted in special paint that would come off easily if the odo was tampered with. Lines appeared between the numbers or something...
Depending on your state, you might be required to put a small decal in the doorjamb that stated the original mileage before the odo was replaced (reset to 0 in your case.)
Just check with your states laws first.
My father put it this way.
Ronny he said...Unlawful is Bending or Breaking the Law.
Illegal is a sick Bird.
There is a You tube video that can guide you.
It pertains to a Re Setting Classic Mustang Odometer .
It is NOT illegal (nor unlawful) to reset your odometer to zero, as it is also not illegal (not unlawful) to replace your speedo with a brand new one that is also set to zero. The illegal (AND unlawful) part is the intent to commit fraud. Read the actual text of the applicable laws, not hearsay. As Allan noted, it is also very easy to disassemble the speedo and reset the odo drum. I typically do this when I completely rebuild a car. Here in VA, the title has a section where you certify if the mileage is correct or not. Falsify this and you are breaking the law. Be truthful and there is no issue whatsoever.
I prefer the Elvis version
True story, In 1975 a guy I know asked me to reset the millage on his 72 Cutlass, was showing 31000, he wanted it to read 75000 for resale, I did as he asked and noticed 6 months later he's is still driving the same car, I asked why he hadn't sold the car (HIS WORDS) It's only got 75000 miles on it , He drove the car another 3-4 years after that.
Here is the CFR for Odometers.
http://uscode.house.gov/view.xhtml?p...edition=prelim.
