Speedminder speedometer
Old April 29th, 2012 | 11:44 AM
rcorrigan5's Avatar
Randy C.
Does anyone have any idea what this speedminder speedometer came out of? I've had it for over 19 years and, although it looks similar to the speedminder speedometer in my '68 4-4-2, it's not the same. The two posts on the back are different. The label is green instead of red. The printed circuit board is blue instead of green. There's a date of "8-66" roughed into the printed circuit board on the back. I'm pretty sure it's out of a '67, but '67 what? Thank you!
Randy C.
Old April 29th, 2012 | 01:19 PM
mrolds69's Avatar
I don't think it's 67, even with that date. Pretty sure it's 68-69 probably a big Olds like a Delta or something. I think that's when they started the pods. I have a speedo around here somewhere that mounts the same.
Old April 29th, 2012 | 01:21 PM
TripDeuces's Avatar
Speedminders I have seen were all in Buicks
Old April 29th, 2012 | 01:32 PM
mrolds69's Avatar
No...they were very common on Olds, my 69 442 has one.
Old April 29th, 2012 | 01:40 PM
2blu442's Avatar
I wouldn't say they were very common, but yes Olds used them too. I've found a couple on 68-72 Cutlass/442's.
It is a nice looking piece Randy, and from the front looks just like a floor shift unit I removed from a 1968 Delta Custom.
John
Old April 29th, 2012 | 04:22 PM
oldspackrat's Avatar
I have speedminders in my Rallye, F85, & Vista cruiser & have seen several others.
Old April 29th, 2012 | 04:29 PM
mrolds69's Avatar
It's like a lot of options that weren't on every car. Back in the day, they weren't real common, maybe. But if you go to the Nats you will see a LOT of them. Things like that were salvaged, the cars were junked, now peeps put them on their restos. I think Brothers has a couple in their inventory.
Old May 1st, 2012 | 06:32 PM
rcorrigan5's Avatar
Randy C.
After looking at Delmontcruiser's postings about his car, I'm pretty sure the speedo pod I pictured above is out of a '67 Delmont 88. The face on the speedo looks identical and the date on the printed circuit board would be consistent with a '67 model car.
Randy C.
Old May 2nd, 2012 | 03:27 AM
Yellowstatue's Avatar
It's a full size Olds speedo and the RPM's per mile are way off compared to a Cutlass... That green label should have the RPM's per mile on it...I think the Cutlass labels are red...
Old May 2nd, 2012 | 06:24 AM
507OLDS's Avatar
I wouldn't say they are real common.I have owned a total of three.I kept one for myself.Mine were all for the floor-shift cars,but have seen a few for column-shift as well.It's hard to put a value on them.
Old May 6th, 2012 | 12:28 AM
67442nut's Avatar
That's not out of a '67.
Looks like '68-'69 to me.
Old May 6th, 2012 | 05:17 AM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
I have 2 for a 66 or 67 .That isnt a 67..
Old May 6th, 2012 | 06:47 AM
tru-blue 442's Avatar
Old School Olds
Maybe a 68 Delmont. It has the screw on for the speedo
cable. Didn't they start using the snap on in 69? The
housing suggests a 68-69.
1001coins
September 2nd, 2014 03:40 PM
jensenracing77
July 13th, 2014 02:13 PM
hadafew
February 15th, 2013 07:17 AM
montvaleplace
May 31st, 2011 07:38 PM
Allan R
April 2nd, 2010 04:32 PM
Quick Reply: Speedminder speedometer
