slip yoke
Old Dec 12, 2020 | 06:32 AM
oldsmobilejim's Avatar
slip yoke
Slip yoke 32 spline fits into 400 turbo that all I know. Any idea in what and year it was used???​​​​​​​
Old Dec 12, 2020 | 07:16 AM
66SportCoupe's Avatar
Yoke
That 32 spline yoke was used on 4x4 vehicles not a car. Car versions do not normally have u bolt u joint on them. This is typical Car TH400 yoke.
Old Dec 12, 2020 | 09:15 AM
Big meaty and bouncy. Lol
Yeah the one in my picture is a Strange Billet 1350 u joint setup for my 66 with the new TH400
Old Dec 12, 2020 | 09:19 AM
I think Spicer's stuff was more truck as well, typically. I could be wrong.
Old Dec 12, 2020 | 09:22 AM
Koda I believe you are correct. Those 1350 Spicer u joints are for a truck. I have 2 solid 1350's now in my setup and had 9 inch built with billet 1350 nose and saddle to handle everything.
Old Dec 12, 2020 | 11:05 AM
You can use a regular car slip yoke on a bolt on output shaft by either machining the slip yoke for the Oring, or machining off the o-ring groove from the output shaft.
The car slip yoke will hit the O-ring retaining groove, preventing the yoke from slipping over the output shaft the last 3/4 inch.
Old Dec 12, 2020 | 11:30 AM
Right. And also of note. The in the original pics this is an open yoke that is designed for a transfer case not being placed inside the output shaft of the transmission.
Old Dec 12, 2020 | 11:51 AM
That TH400 trans yoke is from a Corvette. The ones used in trucks or other vehicles with a multi-part driveshaft will have a provision to allow it to be bolted to the output shaft. This one still slips on the splines.
https://www.corvettemods.com/C3-Corv...ke_p_9032.html
Old Dec 12, 2020 | 11:56 AM
Joe is it just the clip on the output shaft that keeps the fluid from seeping or what?
Old Dec 12, 2020 | 12:05 PM
There should be an o-ring on the output shaft that seals to the ID of the yoke.
Old Dec 12, 2020 | 12:08 PM
Damn Joe. You have pictures of everything??? Lol.
Old Dec 12, 2020 | 12:11 PM
Lol. That is kinda where I was going. Kinda scary.
Old Dec 12, 2020 | 12:19 PM
Interesting and thanks, it will make a good door stop. Oh ya "HO-HO-HO".
Old Dec 12, 2020 | 01:48 PM
Of course. It's called Google Images.
Old Dec 12, 2020 | 04:37 PM
Curious how this assists in answering the original question?
the op was asking what the bolt on yoke was used on. I was explaining how to use a bolt on yoke output shaft trans in a slip yoke application.
Bolt on yokes were used in trucks with divorced transfer cases, and trucks that use a driveshaft with a carrier bearing.
oldsmobilejim
Dec 9, 2020 06:48 PM
JOHNNYOLDS442
Sep 24, 2020 07:24 AM
mister-twister
Feb 12, 2020 09:30 PM
rookieoldsguy72
Jan 24, 2018 12:08 PM
