Shipping a dash, tips and pointers?
Old Feb 6, 2022 | 08:33 AM
GN1220's Avatar
I need to ship a dash and wanted to get feedback from anyone that has shipped one as far as how you packaged it. Obviously I want it to be secure and safe but also packaged as small as possible to save the buyer some money.
Old Feb 6, 2022 | 08:51 AM
69442murph's Avatar
pack it the way you would want to receive it.
jmo....
good luck
Old Feb 6, 2022 | 09:21 AM
RetroRanger's Avatar
72 Olds CS
It will be a custom made box, then double box it. I use a big piece of cardboard like from an appliance. Tape all seams and edges. Pack it well with bubble wrap or styro peanuts. Double boxed packed tight w filler it should travel well. Add insurance too.
if its very nice build a crate out of 2x3 and use luan or similar , but still pack it tight w filler.
if theres any movement when you shake the box its notpacked well enough.
i wonder how a place like just dashes packs their product?
Old Feb 6, 2022 | 09:43 AM
OLDSter Ralph's Avatar
When a box is made, wrap the dash in plastic and place in the box on foam blocks.
Then spray "Blue foam insulation" (Door and Window type) 360 degrees around the dash and on the ends.
Let it cure and it should be fine to ship.
Old Feb 6, 2022 | 12:36 PM
2blu442's Avatar
I've used several layers of bubble wrap. Make the box large enough that you can have a snug fit with the bubble wrap around it. Take pictures of the package before you ship in case it does get damaged and you have to file a claim.
Old Feb 6, 2022 | 02:41 PM
Go to a bicycle shop. Good chance you can get a bicycle box and cut it down.
Old Feb 6, 2022 | 04:50 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Be really safe in PVC but not sure how cheap 8 or 10" PVC is.
What about an 8 or 10" sonic tube with some plywood end caps wood screwed into the ends?
Old Feb 6, 2022 | 05:18 PM
GN1220's Avatar
A dash isn't fitting in a 10" tube, 12" maybe.
Old Feb 7, 2022 | 04:25 AM
fleming442's Avatar
That's a really good idea!
Old Feb 7, 2022 | 04:55 PM
Whole dash or just the pad? What year/model?
Old Feb 7, 2022 | 06:00 PM
GN1220's Avatar
Whole dash, 72. The buyer says FedEx has a perfect size box so I'm going to try that. If not I like the idea of a 12" concrete form tube.
Shot Gun Rich
Oct 14, 2021 10:52 PM
Jimi2much
Aug 5, 2014 08:05 PM
copsupply
Sep 27, 2013 11:27 PM
DENT
Nov 17, 2012 05:02 PM
Kace
Jun 30, 2010 08:08 PM
