Shifter Cable questions
Old Apr 28, 2015 | 11:16 AM
becerra66's Avatar
Damsel in Distress
Unhappy Shifter Cable questions
I bought a shifter cable on ebay for a 69-72 cutlass, but the holes are too small on the cable it self
Shifter Cable A -in this picture I can't slide hole over the the rod for the cable -qstn can I buy another rod or not sure name of the part
Shifter Cable B - I cant get the trunnion_part in the hole - so for the trunnion part Can I buy another part_trunnion with a smaller diameter
Or I could take the trunnion & the rod to shifter shave that down a bit...advice please
Old Apr 28, 2015 | 01:18 PM
Are those different cables? As in they neither one fits correctly?
Do you have a way to measure the diameter of the holes in the cable and the diameter of the rods to see how much they are off?
Old Apr 28, 2015 | 01:46 PM
becerra66's Avatar
Damsel in Distress
thanks Fun71
Ok the shorter cable is the one I removed from my cutlass
the longer one is the one I bought on ebay
Not too concern with the length...or should I be
Im off about less than 1/16... Its a hairline
the trunnion is a 1/4" and the rod to shifter cable
Old Apr 29, 2015 | 10:10 AM
becerra66's Avatar
Damsel in Distress
Got it !!!!
Hey Kenneth Im good thank you for your help as always,
I figured what I am going to do, I dont want to drill out hole on Shifter Cable - I don't want to weaken the metal or holes.
I am going to shave a bit off the rod to shifter lever and shave off the trunnion, I feel confident that fix will work and have me back on the road by saturday...Unless I get off work now...lol
anyways Thanks again
Old Apr 29, 2015 | 02:15 PM
455man's Avatar
I got one from the parts place that had the same problem. I took a drill and drilled out the hole some. it was close and a little shaving made it fit. Both ends needed modified. Just did this mod last weekend.
Old Apr 29, 2015 | 02:34 PM
Octania's Avatar
That looks like a 4" difference in length to me
Dang mfgrs can't even make the holes the right size? sheeeesh
Old Apr 29, 2015 | 03:01 PM
becerra66's Avatar
Damsel in Distress
length....
What's the length its suppose to be...member...they used what ever spare parts they had.
anyone know
Old Apr 29, 2015 | 05:18 PM
Octania's Avatar
I don't think I have one to measure
but in the photo I see two very different sheaths
the cable has an outer sheath that holds still and guides the moving inner core. The outer sheath must be well affixed at each end. It goes around corners and whatnot of course which is why we use cables. But, it can't be too short for obvious reasons, and if too long, the excess has to go somewhere. In your case I see a used broken cable about oh 18" from one sheath anchor to the other, and a new one about oh 4" longer... therefore the new one would have a serious bow if crammed into the place the old one was in. I think it would work poorly and not last long.
If you do get one that fits, then lube it well inside with say spray grease or spray chain lube or similar before installing.
can you share the epay ad link or seller name or something?
part number off its pkg perhaps? UPC code?
Rock Auto is useless here, no cable listed, if you search it directs you to a 91 cent SEAL. Yeah, same thing, sure.
*rolls eyes*
here is one
http://www.ebay.com/itm/68-69-70-71-...671fc1&vxp=mtr
"HERE IS A BRAND NEW AUTOMATIC TRANSMISSION SHIFTER CABLE .
THIS FITS
1968 1969 1970 1971 1972 OLDS CUTLASS 442
WITH TH350 TH400 AND FLOOR CONSOLE SHIFTER
NOT FOR DUAL GATE SHIFTER
IT IS 31.5" LONG overall AND HAS A 19 " MOUNTING DISTANCE BETWEEN U-CLIPS "
here is one that should be right
http://www.ebay.com/itm/69-70-71-72-...bd8d36&vxp=mtr
"1969-70-71-72 442 W-30 W-31 cutlass F-85 Automatic transmission , standard floor shift transmission cable cars with standard console floor shift. (Not for duel gate cars) fits all cars with turbo 350 or turbo 400 transmission. GM part # 407409
This is an exact reproduction of the original in the correct length with the correct foam seals built on the cable. You would swear..."
No size listed. Too much hassle I guess to list the one or two critical fitment features.
Google "gm cable for sale 407409" turns up many interesting items.
gmpartsdirect.com - "407409 has been discontinued from GM"
NOS ones at The Parts Place, somewhat more $ but NOS in correct.
Old Apr 29, 2015 | 06:04 PM
becerra66's Avatar
Damsel in Distress
Sold by belair2door ( 43837 )
- Hide additional actions + Show additional actions
68 69 70 71 72 OLDS CUTLASS 442 W30 SHIFT SHIFTER CABLE...
Contact seller | Leave feedback | Return item | Sell this item
Delivery package 1 of 1
.fastNFreeText { font-size:15px; font-weight: 500; color: green; }
Delivered on Monday, Apr 27, 2015
+ Show shipping details
.additionalShippingInfoBtn { float: right; background: none; border: none; padding: 15px; margin: -15px 0; font-weight: bold; } .additionalShippingInfoBtn:hover { color: #20406a; }
.item { padding-bottom: 20px; } .item:not(:last-child) { border-bottom: 1px dashed #DDD; margin-bottom: 20px; } .img { margin-top: 5px; max-width: 100%; padding: 5px; border: 1px solid #DDD; border-radius: 3px; }
68 69 70 71 72 OLDS CUTLASS 442 W30 SHIFT SHIFTER CABLE with automatic trans
Item price$34.99 Quantity1Item number281343893441 Shipping service USPS Priority Mail
Old Apr 30, 2015 | 06:45 AM
becerra66's Avatar
Damsel in Distress
Thanks Octania...geez man I hope it works...I will replace cable tonight when I get home
I did find a machine shop and shaved off a hairline to get the cable around the rods and trunnion...
Old Aug 11, 2023 | 08:32 PM
mrc816's Avatar
KC442
Can anyone tell me the best way to change out the shift cable?
Old Aug 12, 2023 | 02:05 PM
oldsmobilejim's Avatar
Remove the console, shifter and the cable will be exposed. Raise the vehicle to access underneath. Remove the old, install the new. Adjust, check shifting in all gears. Lower and replace the console.Good luck.
Old Aug 12, 2023 | 07:54 PM
tkcutlass's Avatar
Put the shifter in neutral when adjusting.
Old Aug 13, 2023 | 10:13 AM
mrc816's Avatar
KC442
Thanks you. I will see how it goes.
Old Aug 13, 2023 | 03:54 PM
With tranny in neutral and shifter in neutral. Attach the cable and adjust so both the shifter and tranny eyelets are attached. Slip washer and cotter pin in at the shifter not to spread the cotter pin yet. Now shift into park and slid under the car. Pull the eyelet off the pin at tranny, checking the transmission linkage by wiggling to check that tranny is actually in park if so slide in the cotter pin. If not adjust the cable to align eyelet with pin. When there, drop in the cotter pin. Climb back up and shift into 1st, go under and do the same procedure as you did when checking for park. After that, you'll have to run through the gears. I suggest driving the car and shifting it yourself making sure you can shift into park and downshift to 1st. If all good install washers spread cotter pins install console. Good luck this should help.
Old Aug 14, 2023 | 03:55 PM
How did it turn out?
Old Oct 2, 2023 | 02:09 PM
mrc816's Avatar
KC442
Haven't had any free time to do it but when I do I will definitely update.
JIM'S w30
May 29, 2020 12:41 PM
JOHNNYOLDS442
Jun 2, 2016 01:13 PM
nitrovette
Aug 12, 2014 04:15 PM
onofre442
Jan 24, 2013 11:08 AM
805cut
Aug 30, 2012 06:04 PM
