Shedding some light...
Pop the hood on (I assume) any Oldsmobile of my 'Cruiser's type and a little light should come on. I'll add an "I assume" to this, too, as no matter what I try--from new bulbs to wire-tracing--that thing refuses to work.
Is there a plunger- or other-style switch in the "loop"? My B-Body manual explains the wiring as it should appear, without actually telling you exactly where everything is.
Seems it's the small(est) things that cause the most headaches. Maybe I'll just leave the hood shut and assume it's working (like a backwards refrigerator...).
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
Thanks for the great topic! And thanks for letting me get in on this thread.
I just learned my underhood light does work. I spent alot of time changing bulbs,fuses and running down wiring trying to get this light to work. Just went out,turned on my parking lights,opened the hood and it's working.
I'm always learning stuff around here.![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Any secret to getting the trunk light to work?
![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
Just open the trunk all the way!
These are usually wired to constant 12V, same circuit as courtesy lights.
The switch differs per year and model. Sometimes a mechanical switch, others a merc switch.
My fridge came with a little penguin that controls the light but he drinks WAYYY too much of my beer!
![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
I was hoping I wouldn't have to re-run the wiring or some such drastic measure, but if there isn't a switch or something like it somewhere, I don't see any other alternative.
[Note to self: DO NOT GO LOOKING FOR THINGS TO "FIX." EVER. NO GOOD CAN COME OF IT...
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Follow the wire back to the connector by the firewall. Unhook the connector and see if you have power coming from there. Wouldn't be a bad idea to also see if your ground on the light is blocked by rust.
If all else fails, carry a flashlight in the glove box for when you need it..
If you disconnest the wire from the lamp and have power at the car side with the lights on, you just need a new hood lamp assy (providing ground path is clean.
A unit from many GM cars can be used if originality is not an issue. A stroll through the yarde de junque should land you one...
2blu442
November 9th, 2014 07:16 AM
marxjunk
September 24th, 2014 03:20 AM
