Saved-68 442
Old Nov 15, 2012 | 03:44 PM
sammy's Avatar
Sammy70 455 Supreme
Saved-68 442
Picked up a 68 442 today.....need help with decoding
Cowel
D55 M40V 29
68 34487 05(S)312747
940. 2-1-5. CGG
VIN
3448781111438
On top of water pump...386026. C or 396026G..it was pretty dirty!
Made in Canada
Thanks for help!
Ted
Old Nov 15, 2012 | 05:47 PM
sammy's Avatar
Sammy70 455 Supreme
Vin 3448781111438
3=Olds
44=442 V8
87=2dr Holiday Coupe
8= 1968
1= Oshawa
11438=Production number
Car has wooden sport wheel, black interior floor shift with 3speed with kick down, original radio shoulder belts. Car is all original and not molested
Will post pics soon. BTW, it is Olive Green- a real sleeper
Ted
Old Nov 15, 2012 | 06:31 PM
2blu442's Avatar
Cool! I don't know the casting number well enough, but the correct 400 engine for 1968 would have a large letter G at the end of the number.
Waiting for pictures......
P.S. I've seen 1968 wheels with both real wood and plastic that looks like wood, similar to the shifter *****. Which one do you have?
Old Nov 15, 2012 | 07:33 PM
tru-blue 442's Avatar
Old School Olds
Sounds like you got an original engine
in it. Saweet.
Should have C heads as well.
Old Nov 15, 2012 | 07:52 PM
Ted,
Awesome - you are the proud owner of a Canadian 442!!
Can help with some of the decode for you on the cowl tag
D55 - console shifter
M40 - TH400 Transmission
V29 - ?? You sure it's V29? I think its U29 which is courtesy lighting package
05(S)? I think that should read OS
What you really want is a casting that shows 390925 on your 400. That is supposedly one uber rare engine.
your TR code is 940 - Black vinyl bucket seats and black interior trim
2-1-5 I think this has something to do with the build date and shift. My thought is 2 - second shift (PM or afternoon) 1 - month (Jan) 5 (week)
CGG - This should be your 3 PNT codes. (you may have one of the rarer 2 tone cars) Provincial white roof, willow gold body, willow gold steel rims with poverty caps if I'm not mistaken. If the car has SSII from the factory they would have been argent.
Here's a comparison cowl tag and VIN from a 68 post coupe that was built at Oshawa.
Old Nov 15, 2012 | 09:52 PM
oldzzy's Avatar
wait.... what....
Was that the one that was listed on kijiji in London?
Old Nov 16, 2012 | 02:15 AM
allyolds68's Avatar
Allen
The 396026G is the correct and only block available for 68. (And 69 of course). The original matching numbers 400G block will make this car worth much more than a 66-67 390925E 400E block.
Old Nov 16, 2012 | 03:06 AM
allyolds68's Avatar
Unless this was a Canadian thing there were no real wood steering wheels in 68. There's a really close reproduction one in wood that I think is for the Corvette (?) that I've seen used for the 68's.
Old Nov 16, 2012 | 07:08 PM
2blu442's Avatar
I could be wrong then. Over the years I've seen two 1968's with real wood wheels. One was falling apart from the convertible top being in shreds and rain soaking everything. It may have been from something else but the swap would have dated back to the 1970's.
John
Old Nov 16, 2012 | 08:50 PM
sammy's Avatar
Sammy70 455 Supreme
pics 442
took when i got it home
Old Nov 16, 2012 | 08:57 PM
sammy's Avatar
Sammy70 455 Supreme
bit more...
4 piston caliper ?
396026 G
C heads
Carb 7028251
seats made Jan 3 1968
12 bolt rear. boxed ca, sway bar
orig radio front and rear speakers....
look for engine number tomorrow
Ted
Old Nov 16, 2012 | 09:07 PM
sammy's Avatar
Sammy70 455 Supreme
few more..
few codes found
As1 A81 B32 B33 D55 J52 PW8 U29 U63 U80 Z49
Ted
Old Nov 16, 2012 | 09:15 PM
sammy's Avatar
Sammy70 455 Supreme
Oldzzy, yup this one is from London.It was seller"s fathers. Sat since 1989,and 6 mo ago she floated it to her place where it sat until sh decided to sell. She said she had over 60 e mails in 2 days and around 780 hits on her ad
John, the lock ***** sure look like real wood
More to come....
Ted
Old Nov 16, 2012 | 09:38 PM
Jaybird's Avatar
Your recent purchase looks like quite the challenge. Good luck with it!
Back in the day, I bought the same door lock ***** for my '74 Gremlin X. I wasn't concerned, someone could easily use a coat hanger to break in.
Thankfully, no one tried.
Old Nov 17, 2012 | 11:20 AM
Ted,
Nice score! Lots of TLC coming your way but a nice car to work with. The door lock ***** are aftermarket.
Did you find out what the gearing is and whether it's open or posi?
Old Nov 17, 2012 | 12:24 PM
jaunty75's Avatar
Especially since the car was probably worth less than the bent coat hanger the person would be using to break in.
Old Nov 17, 2012 | 10:47 PM
sammy's Avatar
Sammy70 455 Supreme
-rear end stamp 3917124 N the 3 could be a 8
12 bolt open
have no idea the gears 3.73, one friend said 4.13,4.34??? what did the 442 come with usually in 1968?
Found protecto plate still attached to owners manual
any help would be great !
thanx,
Ted
Old Nov 18, 2012 | 09:15 AM
66-3X2 442's Avatar
Looks to me like the dash stripe is reversed from the others I have seen,thoughts?
Old Nov 18, 2012 | 10:17 AM
Octania's Avatar
Wow, great save. Among the interesting points:
The faux wood steering wheel is pretty rare, nice to see. Same PN was in fact used on Corvettes, and that's how I found my perfect one- years ago, when you could see bidders' name and contact them via ePay, I bid on a 'vette wheel, did not win, but got a note from a 3rd party with one stashed in the basement, and was I interested? The steering wheel and shifter **** should be faux [plastic] wood. The lock ***** are cheesy aftermarket units, probably real wood.
As with all Canadian built 68-9's, your final drive is Chevy [C-] type. Your cowl tag has "344" body style- Lansing built '68 442's did NOT. If you can grab a close nice pic of that I would appreciate it- I collect info like that. Can you post pix or text of the POPlate info? GM of Canada may well have extensive documentation on this car's original configuration.
It looks like an original master cylinder- DO NOT turn it in for a core! Did you say 4-piston disk brakes? Rare as hell and much like Corvette calipers.
Air cleaner looks like the correct OG unit, and HOLY COW IT STILL HAS THE HOT AIR STOVE PARTS. And, it still has the steel PCV tube in the LH side also. It looks like she does NOT have HD cooling - can you spot the water pump ID [RH outlet boss] or the 6-digit casting ID on the inlet runner? Pulley ID codes readable?
It appears to not have heavy duty cooling. Yes, your engine ID is the correct "G" 400. The VIN stamp will probably match your VIN - about 2 fingers below the "C" found on the front of the LH head, on the vertical wall about 1/2 x 2" machined onto the block. It will be absent the "4487" part but otherwise will match the VIN tag. Ditto for the Auto trans - OG tag on RH side, and VIN stamp on LH side, just above the pan gasket, in the cast textured part of the housing. About midway fore-aft in the pan area.
one of your codes is probably the RARE TRIM I see between side windows and headliner - I have only seen this once or twice before, one was a car up north which I just refound a couple weeks ago- and it is a sport coupe I think. Not super exciting, but still a -rare- feature.
Dash stripe looks correct.
The "2-1-5" I believe was basically 5 columns off the Hollerith type Build Sheet Card, so various options would be called out by populating each column with a particular digit- for example, and this part I am just making up, so don't quote this- if you had HD brakes column 1 might be "1"; if you got power DISK brakes instead it would instead be a "2" - various other combinations would lead to [nothing or a dash as you wrote] or 3 or 4 or etc. Same with cooling options in some other column, lighting options in another column, etc.
More photos! Get the rear end ratio by counting turns, or... you know it needs inspection/ fresh juice anyhow... remove the cover and read the #'s stamped into the ring gear- it'll be tooth count- probably 3.07:1 or so for a C type diff ["43 14" would be stamped into the ring gear OD]. They always like to use a prime number for at least one of the tooth counts.
Old Nov 18, 2012 | 10:33 AM
66-3X2 442's Avatar
The picture of the dash stripe is not very clear but it appears the wider stripe is to the inside and the thinner stripe to the outside. The pictures on ROP of an original dash stripe shows the opposite. Would it be possible to get a close up clear picture of the dash stripe in this car? Thanks much.
Old Nov 18, 2012 | 10:38 AM
Octania's Avatar
Judging by how 'most everything else is correct, down to the ALWAYS missing hot air and PCV tube... I'd say the dash stripe, if present, is correct. Now, if the factory did it different on this car, THAT would be great to document.... sure, let's see a good well lit and focused pic of that stripe, especially at say the end.
Old Nov 18, 2012 | 11:15 AM
66-3X2 442's Avatar
It could be that some assembly plants did it different,it could be a Canadian thing,it could be a this car only thing but you're correct,it would be nice to compare/document.
Old Nov 18, 2012 | 01:38 PM
j_link's Avatar
Ted, awesome find! I would like to see more pics...
Old Nov 18, 2012 | 02:57 PM
qjetolds's Avatar
nice find! Can you tell me the code on the steel wheels thanks !
Old Nov 18, 2012 | 03:15 PM
sammy's Avatar
Sammy70 455 Supreme
more pics
more pics of 68 442
Old Nov 18, 2012 | 03:22 PM
66-3X2 442's Avatar
Thanks for the picture of the stripe. It's correct as per the ones I have seen on other cars.
Mike
Old Nov 18, 2012 | 03:27 PM
sammy's Avatar
Sammy70 455 Supreme
more
more pics.....protecto plate found in car will follow.....
Old Nov 18, 2012 | 03:31 PM
66-3X2 442's Avatar
Would it be possible for you to measure the dash stripes? It would be nice if you had a real AMERICAN measuring device.
Old Nov 18, 2012 | 04:15 PM
allyolds68's Avatar
here's mine to compare, his looks a little fatter:
Old Nov 18, 2012 | 04:17 PM
sammy's Avatar
Sammy70 455 Supreme
more
protecto plate and manual out of glove box...
Old Nov 18, 2012 | 04:24 PM
  #31
j_link's Avatar
Any overall shots?
  #32
Octania's Avatar
Wow, thanks for all the photos. I see mostly Lansing built Body Tags, it's great to get some examples of the other varieties.
a 1/10 inch graduated steel rule in the stripe pic would help, but I won't complain. I see the clip that holds the pcv filter in the air cleaner is upside down- minor, minor detail. Great score, nice car to resurrect.
Can you maybe set your shutter to 1/400 second or better, for less blurry, and make sure the camera is on Macro for close shots. That, and brace your hands against a nearby stable object. Use more light as needed to get a good exposure.
Ah, I see that has since been taken care of.
On the POP [interesting half French version] I see 8243162 & T4. Near that should be [under the rust] "OG_____" which is your trans code and exact trans number on its plate of which you have a photo. The T4 should be the rear end code, others probably have that info handy, or see the Chassis Service Manual via WildAboutCars.com... and 8243162 would be your exact Engine Unit Number, which will be stamped into the oil fill tube...
DANG I wish my '68 W30's POP would show up... I have somebody's '68 H/O POP...
You have the dash assembly out already, really? Fast work. No longer "unmolested" eh?
I noted that the VIN rivets, which appear untouched, are put in up from underneath. I can't remember if Lansing cars are done that way or from above.
Old Nov 18, 2012 | 04:33 PM
  #33
66-3X2 442's Avatar
Mike
I can't tell exactly but it looks like the wide stripe is 1/8" & the thin stripe is 1/16",is that what you see? His does look a little larger,that's why I asked if could measure them.
Mike
Old Nov 18, 2012 | 04:46 PM
  #34
sammy's Avatar
Sammy70 455 Supreme
numbers
on protect o plate
940 CGG 3448781111438
8243162 14
OG688383 O5100 85783
owner
His address
date cannot read
Old Nov 18, 2012 | 04:55 PM
  #35
sammy's Avatar
Sammy70 455 Supreme
Could only see last 4 digits of vin on engine plate...1438...
trans matches protect o plate numbers OG 68 8383
The driveshaft turns 4.5 times to 3 rotations of wheel I will take cover off tomorow and get some numbers
The RH outlet boss read 38*783
*O3* I will recheck that again as well as pulley and tranmission numbers
Ted
Old Nov 18, 2012 | 05:00 PM
  #36
sammy's Avatar
Sammy70 455 Supreme
stripes
I will get a measurement on those stripes tomorrow
An overall shot is coming...you must of read my mind today....she aint purdy but it is all there
Old Nov 18, 2012 | 05:19 PM
  #37
sammy's Avatar
Sammy70 455 Supreme
I have not touched the dash . I took out the back seat to get into the trunk ( long story )
And it is the same # on the oil filler tube.
Are you specifcally interested in the W30 POP?
this car will be restored to original,maybe not a 1, but as close as time and $ will allow.
So, based on what you guys have seen so far , is this a matching numbers car?What else should I be looking for?build sheet under tank etc,rear end numbers?
Thanks,
Ted
Old Nov 18, 2012 | 06:20 PM
  #38
gearheads78's Avatar
car guy
very cool find...whats the plans for it?
Old Nov 18, 2012 | 06:37 PM
  #39
sammy's Avatar
Sammy70 455 Supreme
As of this minute, I have no idea! What I would like to do is a complete off frame resto. If all numbers match up , and the car is matching beyond a doubt, then I will. But I will have to do some # crunching!
Ted
Prob should start a build thread, because I realistically know I will restore it
Ted
Old Nov 18, 2012 | 06:40 PM
  #40
sammy's Avatar
Sammy70 455 Supreme
I will look tomorrow and post them for you
Ted
