sand blasting or using a flap disk
Old Oct 14, 2014 | 12:32 PM
wgonzo64's Avatar
when prepping for welding stipping off the old paint and rust which is better SB or FD or both
Old Oct 14, 2014 | 01:14 PM
If your not taking the body down to bare metal all around, I'd just use a flap disc.
Old Oct 15, 2014 | 09:15 AM
wgonzo64's Avatar
well I will be when I weld in a patch panel . so would it benefit me to start with FD then sand blast ???
Old Oct 15, 2014 | 11:48 AM
RandyS's Avatar
I think it would depend on the size of the area you need to work on. A small area can easily be cleaned up using the FD. A large area may be easier and quicker to clean up by blasting. Take care as the use of sand on sheetmetal panels can cause warping and pitting.
Old Oct 15, 2014 | 11:54 AM
wgonzo64's Avatar
yes I am aware of the warping and pitting this can cause thanks for your input __________________
Old Oct 15, 2014 | 12:53 PM
47 Convertible's Avatar
Sand or blast?
Just my nickel's worth: A flap disk is fine for general paint prep if no rust or just very light surface rust, but if area where you intend to weld has even slight pitting from rust, then I'd sand blast that area. A flap disk will not get down and remove rust in the pits and rust will contaminate the weld. Primer and paint over minute bits of rust in the pits will not stop rust from growing eventually either out the far side or causing bubbling on painted surface.
Blasting with sand will remove all traces of rust. Blast with milder media like walnut shell or corn cob will not. If you are not going to weld within an hour or two of sandblast cover the area to be welded with weld-through primer.
Old Oct 15, 2014 | 03:51 PM
CutlassDad's Avatar
Blasting with granular media will be able to get into inside corners, where a flap disc or wheel will be limited to flatter areas and outside corners.
Old Oct 15, 2014 | 04:03 PM
Jetstarjim's Avatar
Also, be sure the metal is good and clean, after you media blast, if you go that route. And, don't forget weld thru primer if you are over lapping anything, or will have no access to corrosion protect the back side.
Mike77
Tech Editor's Desk
Jun 10, 2012 09:28 PM
benji94
Nov 12, 2010 06:49 PM
therobski
Body work
Oct 12, 2010 06:35 PM
dallasite21
Nov 24, 2009 06:41 AM
dynamic88
Nov 3, 2007 08:12 AM
