Right hand rear view mirror
Old Sep 14, 2013 | 03:53 AM
tbristol's Avatar
Hey guys. For those of you who put on a passenger side rear view mirror. Is there a special tool to cut the slots? If not how did you cut the slots?
Thanks.
Old Sep 14, 2013 | 07:26 AM
D. Yaros's Avatar
What year/model?
On my '62 there are holes, not slots? I measured carefully and used a drill.
Old Sep 14, 2013 | 08:51 AM
tbristol's Avatar
70 cutlass. Yes there are round holes with slots off of those. I think old school name was key hole. Because it resembles old time key holes. I can do the round hole. Just not sure how to cut the slots.
Old Sep 14, 2013 | 10:21 AM
Oldsmomick's Avatar
I took a few pictures of the slots I made in the door of my 1970 442. These slots were for the sport mirrors. It has been a while, but I think I just drilled two 5/16" holes and extended the slots with a die grinder. I am sure that it could be done with a combination of flat and round files. The mirror looks to be in the correct position, but I would feel better if someone also had some dimensions to verify (before you cut on the door). Also, I believe a company such as Inline Tube sells a piece of metal for reinforcement on the backside of the door, although I have not yet used one and I have had no problems. I hope that this info. helps. Good luck with your project!
Mick
Re: measurements- The 14 3/4" measurement is taken at the top edge of the blue horizontal tape (along the body line). The measurement that is 1 1/4" down is from the top door body line/edge (not from the innermost top, where the weatherstrip attaches).
Old Sep 14, 2013 | 10:28 AM
tbristol's Avatar
Thank you for the pictures. I was going to make a template. I like your version better. I was going to try a round file. Plus I have some attachments for my dremmel I. Was going to try too. I was just making sure someone hasn't made it simple first.
Old Sep 16, 2013 | 08:33 AM
Tom442's Avatar
Scans of mirror template
I have a an original template that I scanned to PDF files (two pages) if you would like I can email them to you...I will attach them here and you can decide if I need to email them. I used this template for a passenger side mirror on my 68 and am going to use for my Sport Mirrors on my F85 someday.
Got this meesage when trying to add files
Your file of 416.5 KB bytes exceeds the forum's limit of 97.7 KB for this filetype.
Let me have your addy and I can send them.
Tom
68 442
70 F85
Jaybird
May 25, 2021 03:43 AM
Tom442
Nov 30, 2014 07:14 AM
Oct 16, 2013 05:35 PM
Col Wickham
Oct 31, 2009 02:28 PM
Col Wickham
Aug 29, 2009 06:03 PM
