repro floor mats - prob a stupid question
I have these repro mats. Came with the car. On the driver's side, in the upper left hand corner, the circle that is molded into the mat. Is that supposed to be cut out & slipped over the dimmer switch? Just checking before I cut it.
Also, I have a bench seat but only two pair of seat belts. Somehow mine lost the 3rd set for the middle seat over time, correct?
Thanks, Ron
Thanks, Ron
I have the same ones. Yup. Cut out the circle for the dimmer switch. In regards to the seat belts, I have a middle set for the front bench seat. They are stock, but I'm not sure if they were standard for all cutlass'. Mine is a cutlass supreme, so maybe the option packages were different.
gearheads78
Dec 18, 2009 06:15 AM
