Replacing voltage regulator
Old May 19th, 2024 | 08:20 PM
Donaldbabineau's Avatar
I am trying to replace the original voltage regulator with aftermarket because the test indicated this was the problem. The issue I am having is the aftermarket part from either O'Reilly's or AutoZone has a pigtail.connector with 4 tines. How do I connect the new part? There are no instructions.
Old May 19th, 2024 | 08:24 PM
I see a picture of the horn relay / junction block.
Old May 19th, 2024 | 08:26 PM
Okay so my ignorance is obvious. So where is the voltage regulator located
Old May 19th, 2024 | 08:31 PM
On the firewall, slightly off-center towards the passenger side.
Let’s start with model/year first.
Second, how could you run any test or diagnostics without knowing where the suspect components are?
To answer your question, the voltage regulator is on the firewall above the distributor If it’s a 69 or newer 442 the regulator is built into the alternator.
Old May 19th, 2024 | 08:40 PM
The pigtail wiring is in case yours is burned up and needs to be replaced. It yours is OK, then just plug your connector into the new regulator.
This post has pictures of the regulator:
https://classicoldsmobile.com/forums...lass-s-159376/
Old May 19th, 2024 | 08:44 PM
I had the alternator tested after needing a jump and disconnecting the negative on the battery when I got home, charged it. Disconnecting the battery killed the car. I took it to O'Reilly's and had the alternator tested.
This is behind the brake booster
It's a 71 Supreme
Old May 19th, 2024 | 08:56 PM
There is nothing like this on the firewall or anywhere else under the hood that I could see
Old May 19th, 2024 | 09:32 PM
Donald, please show us pictures of your alternator, specifically the harness.
Old May 19th, 2024 | 10:01 PM
Makes sense. It could have an internal regulator. I'll send one tomorrow.
Old May 20th, 2024 | 05:26 AM
Consider performing a Search on this site using the terms: 10SI, 12SI, CS130 & 10DN. This will assist in garnering both visual & logical information regarding external vs. internal VR alternators. You'll be ahead of the game when it comes time to deciphering what ALT and type of wiring you have for discussions moving forward.
Old May 20th, 2024 | 05:43 AM
The left one is internal, the right is external.
Old May 20th, 2024 | 07:42 AM
zl1 camaro's Avatar
In 1971 GM alternators went with the internal regulators.. In 1970 that was as split year for GM, some had internal as well..
Old May 20th, 2024 | 09:09 AM
I think mine is external. There is only the bolt connection.
Old May 20th, 2024 | 09:26 AM
zl1 camaro's Avatar
Yours is internal, it has a 2 wire male connector on the top side not the back side..
Old May 20th, 2024 | 09:27 AM
Correct, "if" the ALT is original. That is why it's important to determine if the ALT is original, aftermarket &/or re-wired.
Old May 20th, 2024 | 09:32 AM
I posted too soon.
Exception: A real 1971 442 came with the open face, "diamond back" 10SI internally-regulated alternator while all others came with the 10DN externally regulated alternator. Always the possibility the ALT has been changed out by a PO.
Old May 20th, 2024 | 09:37 AM
That simplifies things. I believe it has a lifetime warranty from O'Reilly's.
Old May 20th, 2024 | 09:47 AM
zl1 camaro's Avatar
Make sure you ck the voltage @ the battery or back side of main plus wire to alternator with the lights on at 1000 rpm's, you should get a reading from 13.8 to 14.5 volts. good luck glad to help you...
Old May 20th, 2024 | 09:58 AM
Uh, the alternator is not hooked up?
Old May 20th, 2024 | 09:59 AM
zl1 camaro's Avatar
I know, after it is hooked up ck this. Didn't think i needed to state the obvious..
Old May 20th, 2024 | 10:54 AM
Was responding to the picture, not your post.
olds70supreme
March 25th, 2024 03:01 PM
madmax442.com
March 2nd, 2024 12:12 AM
Falkon
August 1st, 2022 02:04 PM
kds 69 442
October 23rd, 2013 03:35 PM
R_CK_R
June 4th, 2013 06:38 AM
