Replacing starter on 330
Old Aug 27, 2017 | 06:57 PM
Tymiles24's Avatar
Any tips on replacing my starter?...it froze up on me this weekend and I had to tap it a couple of times to get it to start. So iam decided to just replace it. It doesn't look too hard to get to and it also looks like I won't have to remove any exhaust pipes around.....any advice would be appreciated
Old Aug 28, 2017 | 05:01 AM
Just be careful with the wiring, disconnect the battery before you start.
Old Aug 28, 2017 | 08:17 AM
The biggest problem with changing a GM starter is the fact that it weighs about 8000 lbs as you are holding it up with one hand while trying to get the bolts started.
Old Aug 28, 2017 | 11:41 AM
Tymiles24's Avatar
Thanks for the info...it looks pretty easy...I am going to get on it here in the next day or so...I want to have it back ready to cruise this weekend..
Old Aug 28, 2017 | 07:33 PM
Put something under it that you can rest it on, like a jack stand, so that 8000 lbs doesn't hit you in the face.
Old Aug 28, 2017 | 07:36 PM
Tymiles24's Avatar
Lol....I'll try that...is it only the two bolts to take out right?
Old Aug 28, 2017 | 11:17 PM
Ozzie's Avatar
If you will be below the starter when removing it, some people leave the cable connected while removing the attaching bolts so as to keep the starter from crashing into your head.
Old Aug 29, 2017 | 06:45 AM
edzolz's Avatar
And remember,... NEVER GET UNDER THE CAR UNLESS IT IS SUPPORTED WITH QUALITY JACKSTANDS. The sheet metal stands that were sold years ago were absolutely not safe. There is no way a regular jack is safe enough either.
Old Aug 29, 2017 | 11:04 AM
Tymiles24's Avatar
Always but thanks for the reminder..
Old Aug 29, 2017 | 05:59 PM
zeeke's Avatar
ahahahahaha, Good Tricep workout though.
Take a good look at where the positive cable connects, when you get it out. If it is fatigued or burned you might want to look into new cables. A bad negative usually causes that. Aside from the weight it's not difficult at all to change. As previously stated disconnect the battery cable for 2 reasons, so it doesn't short and it will allow you to drop the starter lower, but don't let it hit the floor because the start wire and resistor wire are not going to hold it up long. If it makes a violent grinding noise when the new one is in you need shims.
Old Aug 29, 2017 | 06:29 PM
Tymiles24's Avatar
Will the bad ground cause the motor to freeze up like that?...I thought that heat caused the starter motor to freeze up?
Old Aug 29, 2017 | 06:42 PM
Freezing up could be a bad solenoid or worn brushes among other things to include bad cables and connections. Start looking at the simple things first.
griffey57
Aug 20, 2015 08:50 PM
cjsdad
Jun 27, 2015 02:03 AM
at3reg98
Sep 20, 2012 03:57 PM
dartphil
Aug 9, 2012 06:54 AM
cutlassKing
Mar 30, 2007 01:06 AM
