Replacing starter on 330
Any tips on replacing my starter?...it froze up on me this weekend and I had to tap it a couple of times to get it to start. So iam decided to just replace it. It doesn't look too hard to get to and it also looks like I won't have to remove any exhaust pipes around.....any advice would be appreciated
If you will be below the starter when removing it, some people leave the cable connected while removing the attaching bolts so as to keep the starter from crashing into your head.
And remember,... NEVER GET UNDER THE CAR UNLESS IT IS SUPPORTED WITH QUALITY JACKSTANDS. The sheet metal stands that were sold years ago were absolutely not safe. There is no way a regular jack is safe enough either.
Take a good look at where the positive cable connects, when you get it out. If it is fatigued or burned you might want to look into new cables. A bad negative usually causes that. Aside from the weight it's not difficult at all to change. As previously stated disconnect the battery cable for 2 reasons, so it doesn't short and it will allow you to drop the starter lower, but don't let it hit the floor because the start wire and resistor wire are not going to hold it up long. If it makes a violent grinding noise when the new one is in you need shims.
ahahahahaha, Good Tricep workout though.
