Removal of Wiper/Washer plate???
Old May 8, 2010 | 10:57 AM
442oldslawyer's Avatar
I am replacing the woodgrain on the dash of my 70 442 but I don't know how to remove the plate and the oblong **** so I can pull off the old and put on the new. I have done this many years ago but today at 67 I just draw a blank. Shooting blanks too Thanks for any help John
Old May 8, 2010 | 02:06 PM
KRICHEN922's Avatar
It may not be the same on yours but on my 78 it says to twist the headlight **** (left or right can't remember) then use a paper clip to push a pin and remove the ****.
That's a 78 remember, so it may not be the same. I don't know
And thats just for the headlight ****.
If you have a chassis service manual laying around for your car it should help. You might want to get a Fischer body manual for your year as well.
Old May 8, 2010 | 02:51 PM
2blu442's Avatar
John, on your 1970 there should be a small allen screw on the side of the oblong ****. That will remove it. Then for the bezel there's two small nuts on the backside that need to be removed. For that you'll have to come in from the back of the dash to remove them. I can probably find some pictures of the back of the dash/wiper bezel if that would help. John
Old May 8, 2010 | 06:06 PM
Thanks It is coming back. I thought there was an allen screw just could not see it. Will get it out in sun tomorrow.
Old May 8, 2010 | 07:36 PM
Lady72nRob71's Avatar
Here's what the back of the switches are like:
The wiper switch is similar.
If you just want to change the silkscreened faceplate, then a razor blade will pry it off - it is a thin aluminum plate glued to the screwed in bezel.
The bezel comes off once the switch is removed.
Old May 8, 2010 | 09:03 PM
70Post's Avatar
You asked about the chrome plate/bezel. The chrome plate has two very small studs that come out of the back of the chrome plate/bezel. These studs go through the dash plastic. The studs have small stamped "sheet metal" type nuts screwed on from the backside of the dash plastic. Once you remove the **** on the front and the switch assembly on the back you will then able to access these two small fasteners.
Old May 9, 2010 | 09:20 AM
Three screws holding the switch in place. Now for the studs . Too much for an old fat man.
Old May 9, 2010 | 01:17 PM
Got her done. Thanks for the help. Now Vicoden and Makers Mark Happy Mothers Day
bobb
Nov 2, 2010 03:04 PM
oldroyale
Jun 24, 2009 06:07 PM
dingusboy
Apr 29, 2009 05:18 AM
dingusboy
Apr 28, 2009 05:10 AM
Chumley
Jun 19, 2008 07:36 AM
