rear sway bar
Old Dec 14, 2019 | 10:44 PM
leroysr7's Avatar
rear sway bar
have a 87 cutlass doing a budget build looking to improve handling. which rear sway bar would be a better fit for a daily driver.. frame mount are lower control
Old Dec 15, 2019 | 05:00 AM
69HO43's Avatar
Daily driver? Lower Control Arms (LCA). The holes should already be there to mount a factory sway bar, and you can either find someone with sway bar spacers and shims (if needed), or you can make all that yourself or get someone to make them for you if you have to. It'll be easier to find a factory sway bar to fit a Gbody this way. No measuring, adjusting, etc. Bolt it in and go, pretty much. There are generally 2 sizes. F41 (HD suspension) and non-F41 style sway bars. F41 is thicker. If you go aftermarket bar, just get one to fit LCA Gbody and you'll be good.
If you were really going to corner carve, the frame mounted would be better. But for street, you'll be fine with LCA mount.
teamwieland
Jul 27, 2019 07:35 PM
78Cutlass4Speed
Mar 14, 2019 03:03 PM
71OldscutlassS
57
Jan 26, 2019 06:37 PM
frozencaveman
Suspension & Handling
Nov 4, 2017 03:38 PM
Lady72nRob71
Oct 17, 2009 10:48 AM
