rear end question
Old September 27th, 2011 | 08:53 PM
michael hilsabeck's Avatar
rear end question
I have a 1969 olds cutlass s my question is I have a rear end that has a 12 bolt cover and 10 bolt rear end o style. I guess they call it a gm 8.5 what I am trying to do is find a way to make it limited slip or posi tracktion. I dont know the size of gears I can put in it 308s or 373s Im hoping you guys can help me out. Dont got much money so I have to do it right the first time. Thank you. sorry if my spelling is bad
Old September 28th, 2011 | 10:04 AM
Run to Rund's Avatar
You have the "Type O" rear, not the corporate 8.5" that was used by Olds beginning in 1971; it had a 10 bolt cover and ring gear attachment. The performance ratio carrier was for 3.42 and higher numbers. Limited performance parts are available; check Brian Trick (507Olds) on this board.
Old September 28th, 2011 | 06:14 PM
442Harv's Avatar
It's been about 10 years ago, but I put a Alburn unit in my 70. Not sure they still make, but I would check with them.
Old September 28th, 2011 | 07:44 PM
I know i cant do much with the rear end i have . so what can i do go chevy or ford rear end? To get the lower gears i know you guys say NO !!! BUT IT SOUNDS LIKE I DONT HAVE MUCH TO WORK WITH. THAT IS WHY I AM ASKING FOR HELP. I called arownd and everybody said the samething change the rear end that you cant get eanything for them .
Old September 28th, 2011 | 08:54 PM
tmatador's Avatar
I have 70 that had a 12 bolt type O rearend with an open carrier. I bought a posi unit from a guy on this board. monzaz. He has a website as well.
www.jdrace.com
Old September 28th, 2011 | 09:39 PM
Do you know his web site ? I dont want to join another car club . Or phone # thank you
Old September 28th, 2011 | 09:41 PM
tmatador's Avatar
www.jdrace.com
Old September 28th, 2011 | 09:46 PM
oldspackrat's Avatar
I'm pretty sure you can put a '71 or later type rear end in your car with little/no problem. They have a 10 bolt cover, 8.5 ring gear, & parts are much easier to get than for the original '70 type. I can supply you with a rear end core to be rebuilt, or Brian trick(507olds) I believe can supply you with anything you need.
Good luck.
350TurBRO
September 12th, 2014 12:52 PM
72greensupreme
Drivetrain/Differentials
March 25th, 2009 07:13 AM
1964Jet*88
July 21st, 2008 06:26 PM
1964Jet*88
July 20th, 2008 10:05 AM
Good_Music_n_Cars
October 16th, 2007 08:35 PM
