Rally Steering Wheel Question
Old Aug 7, 2023 | 02:55 AM
rudeke's Avatar
Were these steering wheels reproduction / aftermarket only? Were they ever original equipment? If so, how would one know the difference between original and reproduction / aftermarket?
Old Aug 7, 2023 | 05:59 AM
VC455's Avatar
Barely Registered
There were a few wheels, called Custom Sport, available from 1969 on. The option code was N34.
Reproductions are made, at least of the first one pictured below. The reproductions appear to my unpracticed eye, to be remarkable faithful to the originals. So much so that one would assume they were made by the same manufacturer (I don't know that to be the case, howevver).
Old Aug 7, 2023 | 06:06 AM
Yeah, there are no repros for the 1969 wheel. That's why they sell for over $1000.
Old Aug 7, 2023 | 12:23 PM
What was the nomenclature/option code for the '68 faux wood 3-spoke wheel?
Old Aug 7, 2023 | 12:42 PM
RPO N34.
Old Aug 7, 2023 | 03:04 PM
72442TwiceOwned's Avatar
I haven’t inspected a reproduction of the first one pictured above (the four spoke) but I have an original that came on my 72. I have heard this before and also witnessed on my own that if the car is stored or sits unused for a while, the wheel itself becomes sticky. I don’t know if this would occur on a newer reproduction but it seems it would be due to age/some sort of breakdown more than anything. If you find a sticky one it could possibly be an indication of an original - purely a guess. Windex took care of the problem on mine.
Old Aug 7, 2023 | 04:28 PM
rudeke's Avatar
Thanks for the replies. This forum rocks. My wheel has its fair share of sticky! Maybe original?
Old Aug 7, 2023 | 04:32 PM
The stickiness is due to outgassing of the rubber. Sitting under the windshield in the sun makes it worse. The easiest way to remove the residue is with paint pre-cleaner, like Prep-All. Wipe it down whenever needed.
Old Aug 7, 2023 | 04:44 PM
4speed455's Avatar
If your wheel is the 4 spoke what does the grain look like on the front of the wheel? Most originals I have seen are worn almost completely smooth on the front side with varying amount of grain on the backside still remaining. There is also a part number on the backside of one of the spokes molded into the rubber. My reproduction has the number stamped into the rubber were the originals have it raised above the rubber.
Old Aug 7, 2023 | 05:22 PM
You’re definitely right about this forum. I just joined this one yesterday after trying another one the day before. Almost immediate replies to my “Newbie” post. Tons of activity here. Not even a “welcome” on the other site.
Old Aug 7, 2023 | 05:54 PM
The stickiness is due to inadequate vulcanizing (curing). You should NEVER have to apply these products to a properly cured rubber (either synthetic or latex) product. I've witnessed many threads regarding this phenomena and the plain truth is the vulcanization of the rubber is CRAPOLA.
Old Aug 7, 2023 | 06:09 PM
crossboss's Avatar
Past owned:
Guys,
Is that N34 wheel available in a re-pro?
Thanks.
Old Aug 7, 2023 | 06:39 PM
3clicks's Avatar
The 70 and later wheel is available as a repro but the three spoke 1969 wheel, as Joe pointed out, is not. Both steering wheels share the same N34 option code.
Old Aug 7, 2023 | 07:21 PM
Originally Posted by crossboss
Guys,
Than4ks.
See posts #2 and #3.
Old Aug 7, 2023 | 08:12 PM
joes_olds's Avatar
Guys,
Thanks.
https://www.fusickautomotiveproducts...s.asp?dept=327
Old Aug 8, 2023 | 06:11 AM
69 Hurst's Avatar
Olds Fanatic
RPO N34.
Those prices make you want to cry...
Old Aug 8, 2023 | 06:07 PM
Median annual household income in 1968 was $7,700. Can't say that I'd want to go back to that.
67442nut
Jan 15, 2021 06:29 PM
joesw31
Dec 30, 2016 03:39 PM
rhett838
Jul 14, 2013 05:46 PM
Mr442
Feb 23, 2013 10:27 PM
Southern_Hospitality
May 22, 2009 03:23 PM
