Radiator top plate 68 or 69
Old Oct 2, 2015 | 03:21 PM
kevdog442's Avatar
Member
Can I use a 69 top plate to install a 4 core radiator in my 68 Cutlass? They are much easier to find.
Old Oct 2, 2015 | 05:26 PM
allyolds68's Avatar
Do you have four core lower saddles? You can spread a regular non-four core 68 top plate to work. You can also use a 67 top plate and with a little modification it is exactly the same as a 68 four core top plate.
Old Oct 2, 2015 | 06:58 PM
kevdog442's Avatar
Member
Yes I have the lower saddles, and probably will just modify the top plate. Was just thinking a 69 4 core plate would look better if it fit. They are reproduced so easy to find.
Old Oct 2, 2015 | 10:24 PM
Yellowstatue's Avatar
I don't think a '69 four row top plate is any easier to find than a '68 four row top plate. I have a half dozen '69 three row top plates but no four row plates.
Old Oct 3, 2015 | 05:04 AM
kevdog442's Avatar
Member
Yeah they are being reproduced for around $125 by a couple different suppliers.
I know it wouldn't be correct but would probably look better than bending up my 68 plate
Old Oct 4, 2015 | 04:47 AM
allyolds68's Avatar
I'm pretty sure I have a spare 67 that is identical to the 68 four core except it has to be notched and a couple more holes drilled (and I believe the saddles widened) for $50 if you're interested.
Old Oct 6, 2015 | 06:46 PM
kjr442's Avatar
Kjr442
I have the complete set up for sale, four core radiator/four speed application, shroud, and top plate. pm me if you want it.
Old Oct 7, 2015 | 06:11 PM
kevdog442's Avatar
Member
Pm sent
Old Oct 7, 2015 | 06:12 PM
kevdog442's Avatar
Member
Pm sent
Alex72cutty
Apr 21, 2015 10:30 AM
olds455
May 11, 2010 08:18 PM
w-30dreamin
Jan 31, 2010 03:20 PM
68conv455
May 12, 2008 04:46 PM
Resto Guy
Apr 28, 2008 07:48 PM
