Radiator tags
Old Mar 5, 2025 | 01:03 PM
JLawrence's Avatar
Radiator tags
Anyone here knowledgeable about radiator tags? Trying to figure out what radiator or radiator tag should be in my '71W30. My 70 olds has a tag. My 71 does no
t
Old Mar 5, 2025 | 02:56 PM
Mr Shifty Sidney's Avatar
There is a table in the assembly manual that has the radiator information you are wanting. Let me know if you do not have a manual and I will post. Good luck.
Don W
Old Mar 5, 2025 | 11:37 PM
JLawrence's Avatar
Don W
I don't have one of those
Old Mar 6, 2025 | 04:00 AM
Old Mar 6, 2025 | 11:19 AM
RocketDevo's Avatar
That's good info Vintage Chief posted, unfortunately its missing a key Rad Tag Code.
The "EF" rad code tag is a secondary tag used when the primary "EB" rad code is not available.
The EF is a 4 core tank on the passenger side and a 3 core tank on the drivers, which makes it a 3 core.
The EB is a true 4 core.
If your car has 3:73 gears or AC the EB is the rad tag code you need.
The EF is the secondary option but is also correct.
Both are Extremely difficult to find.
Hope that helps.
Old Mar 6, 2025 | 11:51 AM
Rocket - Thank you for chiming in.
68Z28
Jan 12, 2023 04:47 PM
Indy Guy
Jan 26, 2022 08:01 AM
grannys442
Oct 30, 2021 08:25 PM
costpenn
May 23, 2014 04:26 PM
toro455
Jul 4, 2010 01:45 PM
