Quick Question
From: Orion Township Michigan 30 Miles North of the Murder City
Quick Question
I just have a Quick Question and I hope it doesnt turn into a DonneyBrook.Like my Last Post.
I recently had all of my Body Mounts changed out after the restoration.
The Rag Joint also had to be changed due to alignment dynamics.There was a Ground Strap on the Rag Joint that was disconnected.
When we re-assembled the Steering Column to the Steering Gear we made sure the Ground Strap was re attatched.Now the car is Running on what seems to be 4 Cylinders.Terrible Performance.is there any connect between that Ground on the Rag Joint and the Ignition.Thanks in adavance.
Ron Roth
586-556-1234
Detroit Michigan.
Garden Capitol of Mid America.
I did that for you
"Cold War"
AKA
"Psuedo Intellectual "
Ron Roth
586-556-1234
Detroit Michigan.
I did that for you
"Cold War"
AKA
And stop threatening people. You're so violent and mean!
Good Evening Mr. Roth - Something you might consider is 'the doctrine of clean hands':
http://en.wikipedia.org/wiki/Unclean_hands
Read that carefully if you care to, its general information only, not meant to represent legal advice. Best of luck to you.
