Question regarding Intake manifold
So it appears as though i will be rebuilding the 3.8L v6 on my 85 cutlass. I was looking for intake manifolds but i only found a couple (one of them being an intake manifold for the buick v6), is that one compatible with my engine? Are the buick/olds engines the same? Thanks in advance for your help!
i have been thinking of doing a engine swap down the line in my Cutlass Sedan... i was thinking big block or large small block... i think i will clean up the 3.8L in mine for time being and fix its leaks till i get around to finding an engine to replace what it has... have you thought about getting heads redone, along with them ported along with the intake?
If I remember correctly, the front cover on those 3.8 are part of the oil pump.
So make sure you inspect that area for wear. And
there is/was a good v6 book out there for sale by S.A. Design that covered v6.
VinMichael
Apr 2, 2012 08:17 PM
