Question for chemical guys
Old May 14, 2024 | 06:28 AM
oldsrush's Avatar
Gearhead
Trying to make an anodize stripping solution for some headlight bezels. If I mix 2lbs. of crystal lye with 3 gallons of water, what % of caustic solution will I have?
Old May 14, 2024 | 06:30 AM
I don't know the mix %, but be careful with aluminum parts and lye. Lye and aluminum equals hydrogen.
Old May 14, 2024 | 08:26 AM
Charlie Jones's Avatar
Phantom Phixer
I've never heard of stripping anodizing with lye.
Most of the time aluminum trim parts are repaired, polished, and re-anodized.
The polishing removes the anodizing.
Old May 14, 2024 | 08:38 AM
8% NaOH solution (908g NaOH/11340g H2O)
Where 908g = weight of 2 lbs NaOH (solute); 11340g = weight of 3 gals H2O (solvent)
Old May 14, 2024 | 09:03 AM
oldsrush's Avatar
Gearhead
Thanks for the reply! How much more lye do I need to add to obtain 30% caustic solution?
Old May 14, 2024 | 09:37 AM
Solving for x
x/11340g = 30% (0.30)
x = 11340g X 0.30g = 3402g
3402g - 908g = 2494g
You will need to add an additional 2494g NaOH to 11340g (3gals) H2O to achieve a 30% NaOH solution
x/y = z
Where x = g NaOH; y= g H20; z = %
x = 908g NaOH; y = 11340g H2O; then, 908g/11340g = 8% (0.08)
x = 3402g NaOH; y = 11340 H2O; then 3402g/11340g = 30% (0.30)
Old May 14, 2024 | 09:55 AM
GN1220's Avatar
EZ Off oven cleaner in the yellow can works. Sounds a lot easier.
Old May 14, 2024 | 10:01 AM
I prefer to use grams to pounds, but this equation is simple if you remain in pounds (or you can make the equivalent adjustments in ounces if you like). Simple stuff, you just need(ed) to get your equivalents.
1gal H2O = 8.34lbs; therefore, 8.34lbs X 3 (gals H2O) = 25.02lbs (H2O)
2lbs NaOH/25.02lbs H2O = 8% (0.08) NaOH solution
Again, simply solve for x
x
/y = z
If z = 30% (0.30) what is x?
x = y X z (25.02lbs X 0.30) = 7.5lbs NaOH
Therefore, 7.5 lbs - 2 lbs = 5.5 lbs. You'll need to add an additional 5.5lbs to a known 8% NaOH solution to achieve a 30% NaOH solution. Think about it logically & you can quickly do the math in your head. If 2lbs NaOH in 25lbs H2O = 8%, you know you'll need roughly x4 times that amount to achieve a 32% NaOH solution.
Old May 14, 2024 | 10:54 AM
oldsrush's Avatar
Gearhead
Thanks Norm, impressive math skills For anyone following, the anodize is a very hard surface and very hard to just sand or polish off. 10 minutes in caustic solution and you can start polishing after any repair work.
Old May 14, 2024 | 11:32 AM
GN1220's Avatar
Again, I've had success with EZ off.
Old May 14, 2024 | 02:17 PM
oldsrush's Avatar
Gearhead
Thanks for the tip, I will give it a try.
Old May 14, 2024 | 02:42 PM
Other than providing you with answer(s) to your question(s) regarding % NaOH solution, two caveats to consider in EZ-Off application(s):
(1) Do not use the EZ-Off Fume Free product as it contains no NaOH; and,
(2) Easy Off Heavy Duty Oven Cleaner Aerosol contains ≤10% NaOH. So a little less than the 30% solution you were after but should work effectively none-the-less. I use the Easy Off Heavy Duty Over Cleaner Aerosol to clean engine parts (intake manifold etc. made of iron). I've never used it to remove the Al anodized layer.
JoeP told be Wal-Mart sells an oven cleaner much less expensive than Easy Off. I'll see if it I can find it.
Easy Off Heavy Duty Oven Cleaner Aerosol MSDS
EASY-OFF®Fume Free Oven Cleaner
Old May 14, 2024 | 02:49 PM
I found the post where JoeP told me about the WalMart oven cleaner, but I never bought any. I'll see if I can find it.
Post>>> 9
Old May 14, 2024 | 06:43 PM
Tedd Thompson's Avatar
Us common folk call oven cleaner Sodium Hydroxide, used in bluing salts for bluing guns and a bunch of other cleaning tasks, and it will make any aluminum you have mistakenly left in the salts disappear..Tedd
Old May 14, 2024 | 07:07 PM
I guess us even more common folks call Lye Sodium Hydroxide since it has been used in making soap before they made oven cleaners.
Old May 14, 2024 | 08:20 PM
This common folk just uses soapy paper towels to clean all the oven he can, then runs the cleaning cycle and gets the ash later. That serious of an oven cleaner makes me wonder about the grease fire in waiting that needed it in the first place.
Old May 15, 2024 | 04:06 AM
We've gone from making a caustic NaOH solution to cleaning ovens. LOL
Old May 15, 2024 | 05:25 AM
GN1220's Avatar
Make sure it's the good ol yellow can of EZ Off, the blue doesn't work.
Old May 15, 2024 | 05:40 AM
Post #12
Old May 15, 2024 | 06:25 AM
oldsrush's Avatar
Gearhead
All this oven cleaning talk makes me want to clean the wife's oven....not
Old May 15, 2024 | 10:07 AM
F-85 4-4-2's Avatar
Not to be a jerk (although it does come easily), that mix would be a 7.41% solution. 908g/(11,340g + 908g) = 908g/12,248g = 0.0741.
More fun is the negative heat of solution of NaOH. 50g NaOH dissolved in 117g 68F water (a 30% solution) would go to 211F (assuming no heat loss).
Old May 15, 2024 | 11:17 AM
oldsrush's Avatar
Gearhead
I was amazed at how warm it got when I mixed in the first 2 lbs. of lye. Getting ready to add 2 more lbs. ,is it going to get even hotter?
Old May 15, 2024 | 11:46 AM
You are absolutely correct & you're not being a jerk. I was trying to keep it as simple as possible w/in reasonable terms of a weight-weight ratio which most could follow in an automotive forum.
I trust we aren't next going to determine heat of enthalpy of this Rxn?
Old May 15, 2024 | 12:02 PM
Dissolving lye (NaOH = Sodium Hydroxide = solute) into H2O (solvent) is a highly exothermic Rxn releasing energy in the form of heat. You should always add the solute (NaOH) to the solvent(H2O) slowly. Just as you would with a strong acid such as HCl (Hydrochloric Acid = Muriatic Acid). You would never want to add water to NaOH or water to HCl. You add the solute (e.g. NaOH) to the solvent (e.g. H2O).
In chemistry we say: "Do as you oughta, add acid to water". This provides a simple mental cue to assist in abiding by safety rules when dealing with strong bases and strong acids, but it should be used whenever you're mixing solvents and solutes to create a solution.
Old May 15, 2024 | 12:16 PM
F-85 4-4-2's Avatar
Next two pounds will give you a little less temperature increase, only because your solution is now 27-lbs, versus the 25-lbs of water you began with. Be careful, and eye protection is a must!
Old May 15, 2024 | 12:57 PM
There's obviously no manner to tell what someone's background is when working with nearly anything - albeit, I just answer questions. As F-85 stated wear gloves & eye protection - always.
To be clear. A strong base (NaOH) solution burn is FAR, FAR more damaging to your body (especially mucous membranes) than a strong acid burn. Bases will literally eat away your adipose (fat) tissue in a heart beat and continue eating (dissolving) it deeper and further. You'd much prefer to have an acid burn than a base burn. None-the-less, with that said:
(1) Clearly label the NaOH solution container - VERY CLEARLY IN LARGE PRINT
(2) NEVER store a strong base (NaOH) solution or strong acid solution above ground. ALWAYS store them at ground level.
(3) Both strong acid solutions and strong base solutions REQUIRE a lid.
Old May 15, 2024 | 01:14 PM
I guess I'm not really beating it to death if I'm referring to safety - so, I'll rant one more time in the name of safety.
Accidents happen. If yourself or anyone should spill Sodium Hydroxide solution on themselves, IMMEDIATELY run large copious amounts of COOL water (not warm, not hot) over the area of skin. Bases (e.g. NaOH solution) like bleach (Sodium Hypochlorite) are slippery to the touch. Continue running cool water over the area of skin during the 1st hour - every 15' to 20'.
Old May 15, 2024 | 01:20 PM
oldsrush's Avatar
Gearhead
Got the first one stripped. Had to add another gallon of water to keep bezel submerged so now I have 4 gallons of solution. Added 3 lbs. more of lye so according to my calculation I now have around 15% solution. The bezel below was submerged for 15 minutes and it appears to be stripped pretty good. Now the hard part, sanding and removing factory flaws, then polishing before anodizing.
Old May 15, 2024 | 01:26 PM
Looks good.
Old May 19, 2024 | 12:45 PM
oldsrush's Avatar
Gearhead
First lesson learned when stripping anodize, sand or brush the black trim paint off first. Where the black gets left anodize remains and you have to dip it again in the solution.
Chuxter
Mar 27, 2023 08:00 PM
firstoldsmobile
Dec 17, 2020 05:13 AM
olds70supreme
May 3, 2018 05:00 AM
brianbeez67
Care and Appearance
Apr 25, 2017 07:14 PM
sparky44268
Mar 15, 2011 03:34 PM
