Quadrojet Carb
Old Dec 5, 2014 | 03:25 AM
Cincinnati Rick's Avatar
Quadrojet Carb
I'm going to sell this carburetor. Looking for help to set a value. It was in a box of parts that came with a 1970 442 that I purchased.
Old Dec 5, 2014 | 03:33 AM
Another pic
Old Dec 5, 2014 | 04:05 AM
jcdynamic88's Avatar
q-jet
you will need to see what the carb # is to identify it's year/application,driver's side of carb body.appears to be from a pontiac to me .
Old Dec 5, 2014 | 05:46 AM
cherokeepeople's Avatar
if that last pic was a little more to the right we could have seen the carb number.
Old Dec 5, 2014 | 11:24 AM
I will take another photo of the part number this weekend when I get back to my shop.
Old Dec 5, 2014 | 12:00 PM
tru-blue 442's Avatar
Old School Olds
Early Chev pickup? Those #'s will tell the story.
Old Dec 5, 2014 | 12:56 PM
mrolds69's Avatar
I would agree with Jim, looks like Pontiac, cuz' those are the carbs that usually have that big vent in the front. Could be a good one...get the #'s.
Old Dec 5, 2014 | 01:05 PM
GEARMAN69's Avatar
Ditto, good early 70's Pontiac one maybe. The ones with the secondary flap cut outs have larger holes for the fuel transition and are good performing HP models generally
Old Dec 5, 2014 | 07:18 PM
all chevy ones i have seen the fuel enters from the pass side.olds and pontiac from the front.
Old Dec 5, 2014 | 08:36 PM
67442nut's Avatar
Early Olds Quadrajets fuel inlets also enter from the passenger's side.
Old Dec 5, 2014 | 08:38 PM
marxjunk's Avatar
The "GOOD" pontiacs have divorced chokes
the air flaps on the secondaries do look pontiac..but the throttle arm is nothing like a pontiac...since its a carter style q-jet, its prob some type of universal service piece..it does have the 71 up vent
ive seen some real good carbs go thru the rebuilder shack and come back as a pieced together mess...but the bowl numbers where real good numbers
Old Dec 6, 2014 | 04:33 PM
Once he posts the number, we'll know. Carter Quadrajets numbered like Rochesters are not universal replacements, but specific to their application. Carters numbered with a 4 digit Carter code are technically "aftermarket," so they'd be more universal, as you say.
Old Dec 9, 2014 | 05:14 PM
I looked all over this carb and these are the only numbers I saw
Old Dec 9, 2014 | 05:48 PM
Old School Olds
Try looking here. Yours looks pretty crusty. The #'s are probably hiding from you.
Old Dec 9, 2014 | 05:52 PM
I'll look again tomorrow when I'm at the garage. I sure didn't see anything though.
Old Dec 9, 2014 | 05:57 PM
Old School Olds
The flat spot or shelf on the main body is where to look.
You can barley make out the #'s on the pic I posted.
But it gives you the spot that will tell what it was made for.
Can you see where I'm talking about?
Old Dec 9, 2014 | 06:00 PM
I really can't see the numbers on yours but I'll know where to look now on mine
Old Dec 9, 2014 | 06:01 PM
How many digit number will it be?
Old Dec 9, 2014 | 06:02 PM
RetroRanger's Avatar
72 Olds CS
to make it a little clearer
Old Dec 9, 2014 | 06:05 PM
I see it now! I'll check back tomorrow with a number
Old Dec 9, 2014 | 06:08 PM
Old School Olds
Wicked cool peuter skills retro, thanks.
Old Dec 10, 2014 | 09:58 AM
OK....Here are the numbers I found:
704326G C3 JJ
Old Dec 10, 2014 | 05:31 PM
GEARMAN69's Avatar
If that G on the end is actually a 0 zero as it should be a number. It would be 7043260 off a 73 Olds 350 Omega/Cutlass
Old Dec 10, 2014 | 08:26 PM
Thanks Gearman. I'd like to get rid of it. Do you have any idea of the value of it? ...if any
Old Dec 11, 2014 | 05:13 AM
GEARMAN69's Avatar
I doubt it is too highly sought after but does have the good top.. Maybe a 100 ?
Old Dec 11, 2014 | 06:40 AM
OK...I'll throw it out there and see if there's any interest.
Thanks again GearMan
Old Dec 11, 2014 | 07:00 AM
billmerbach's Avatar
major noob
I heard omega
Old Dec 11, 2014 | 07:43 AM
Old School Olds
Remember guys, those#'s are just the main body #'s.
These Q-J's have know to have been cobbled together over the years.
Old Dec 11, 2014 | 07:26 PM
I looked closer and the number is actually 7043266 not 7043260. It appears to be off a 1973 Pontiac 400 or 455 motor.
Old Dec 11, 2014 | 09:05 PM
Octania's Avatar
Rt-click
open with...
Pain[t]
Draw a red box... or maybe another color for Not-a-problem
Add text as you wish
Save As...
change file name
Not that tough.
Please, all y'all, do this before putting forth photos on the net
Like adding text to known REAL or FAKED part number stamps so later we all know what is being shown.
Olds #'s are [after 1967 or so] in the '250's
260's and 270's maybe are Pontiac.
Google brings up all kinds of information, some of it is even useful.
Works well on numbers.
Of course, if you know where to find the most crucial number, that helps.
Old Dec 12, 2014 | 05:46 PM
  #31
cjsdad's Avatar
Since the discussion has visited the realm of which body goes with which vehicle, riddle me this BatMen! I have a Q-Jet that I bought for a Sawbuck to put on my Cutlass thinking the fuel inlet was in the right place. But when I run the number (17056212 ABH) I get '76 Chevy Puckup with a 454. Divorced choke style. It looks like I can put a choke on it so that is not a big concern, but will it work right? The gasket between the baseplate and body has been squeezed out into the secondary cavity preventing them from opening so someone tried to wire them to the linkage and force them to open. A gasket kit will fix that, but what about the over-torqued top plate? Can that be straightened out and work right? Do I need another parts unit to repair this thing?
Old Dec 13, 2014 | 10:22 AM
  #32
Gary M's Avatar
Warp repair
Barker GangGarage in Colorado. He uses an oven and jig to safely straighten it. He did mine. Works great. He on the internet.
Old Dec 15, 2014 | 05:10 PM
  #33
GEARMAN69's Avatar
Since it turned out to be a 7043266 73 Pontiac carb it may be a little easier to sell if you advertise it as such
W-27
Jun 9, 2015 12:25 AM
wyteon
Feb 17, 2015 06:31 AM
W-27
Mar 19, 2014 09:43 AM
ragtopblue
Jun 4, 2013 08:43 PM
ros6872
Aug 1, 2011 09:44 AM
