Quadrajet question
Old Aug 2, 2015 | 04:02 PM
Sampson's Avatar
Quadrajet question
I could use some advice from the carb guru's.
I have a recently rebuilt and tuned quadrajet. It has a slight stumble off idle. I blamed it on timing and possibly low idle.
I worked this weekend to address those issues and it still had the off idle stumble. I looked down the carb at the squirters and it only squirted on the drivers side. Any ideas what is up?
Old Aug 2, 2015 | 04:42 PM
pogo69's Avatar
morgan
You can try removing the 5/8 fuel inlet nut and blowing compreesd air in the neck and see if it clears the passage out
Old Aug 3, 2015 | 05:51 PM
61reoldsman's Avatar
Have a look at the accelerator pump cup I bet it is ripped.Did you replace the accelerator pump? If it is ,it doesn't push through enough fuel to the squirters . Unfortunately you'd have to the carb apart again.
Old Aug 3, 2015 | 05:53 PM
Octania's Avatar
or, dirty/ clogged passage. Dismantle, clean, reassemble.
Old Aug 3, 2015 | 07:20 PM
onetogofast's Avatar
Accelerator pump or clogged squirter...
Old Aug 3, 2015 | 07:30 PM
Wear safety glasses. Those carb channels do u turns and your air blaster might put fuel in your eyes.
Old Aug 6, 2015 | 03:58 PM
Sampson's Avatar
Thanks for the suggestions guys. I will try blowing through the inlet this weekend and if that doesn't work pull the top off and check the pump and passages.
Old Aug 6, 2015 | 04:46 PM
Octania's Avatar
Inlet only goes past needle and seat into the bowl.
Not all that connected to the accel. circuit.
Easy enough to try though.
auto_editor
Dec 20, 2010 11:24 PM
1964CutlassSC
Feb 18, 2010 08:05 PM
sworthy555
Feb 16, 2010 08:25 PM
sixty9olds
Sep 10, 2009 04:56 AM
PmL69
Jul 3, 2009 06:52 AM
