Quadrajet
Old Jul 28, 2014 | 10:24 PM
irkennedy's Avatar
Quadrajet
Guys,
What size Quadrajet (CFM) came on the original stock Olds 425? I hoping to see if a quadrajet I found in my garage will work on my 455. I need to get rid of this 650 Edelbrock
Old Jul 29, 2014 | 03:05 AM
Seff's Avatar
I posted this quote, knowing the dodgy nature of the Olds FAQ, because I know people will correct me if it's wrong. Please don't make your decision based only on this.
Originally Posted by Olds FAQ
It's easy to overestimate the CFM requirements of an engine. You can calculate the cfm your engine flows using the formula everyone on this list has probably seen many times:
engine CFM = (engine CID x max rpm x volumetric efficiency)/3456
Now for a stock 455, I'll assume you won't go above 5500rpm, and stock heads with stock exhaust manifolds is probably going to keep your volumetric efficiency no higher than 85% at 5500 rpm. So your engine needs - only 615 cfm!
Here is where the universal misunderstanding begins. Usually people ignore the formula above, or use a rule-of-thumb like "use 1.5 times the airflow predicted by the formula". The fact is that 4-bbl carburetors are rated for their cfm when there is 1.5" of vaccuum sucking on them. If you use a 600cfm carb on your 455, there will be about 1.5" of pressure drop across it when your engine is at max rpm. Since atmospheric pressure is about 30 inches of pressure, you just took away 1.5" from 30", leaving the engine about 5% down on power compared to a much bigger carb. If your engine makes 300 real-world horses with those exhaust manifolds and stock heads, using the 600 cfm carburetor costs you only about 15 hp, at max rpm. Everywhere else in the rpm band the engine will be more responsive with this small carb, the car will feel better in traffic, get better gas mileage, etc. Unless the car is a drag-race only car, the 5% power drop at max rpm is really not very significant - how many minutes a day does your car spend at 10% throttle? How many at WOT? How many at WOT and 5500 rpm?
So I'd say pick any carb that flows at least 600 cfm (I believe all the true 4-bbl Quadrajets do), tune it to match your car and driving style, and you'll enjoy life with it. On the other hand, bolt on a 1050 cfm Dominator, and you'll probably be miserable with the result.
Old Jul 29, 2014 | 08:52 AM
455man's Avatar
Stock quad is 750 for most. How much cfm it's pulling depends on the motor.
Old Jul 29, 2014 | 05:01 PM
Sampson's Avatar
To Seth's point above the QJet is the best of both worlds. Small primaries up front for around town normal driving and BIG Secondaries for those WOT bursts down the track.
Old Jul 30, 2014 | 05:18 PM
oldolds88's Avatar
i dont think 425 had a 4 bbl on them. did they?
Old Jul 30, 2014 | 06:11 PM
Yep, some had 2bbl and some had 4bbl. Just like 330s, 350s, 400s, and 455s.
Old Jul 30, 2014 | 07:37 PM
Surely you jest.
auto_editor
Dec 20, 2010 11:24 PM
orange442
Oct 8, 2010 08:37 AM
mitsudave
Nov 17, 2007 07:49 PM
chevelle_ss
Feb 2, 2007 05:51 AM
Thomas Simcich
Oct 30, 2005 06:11 AM
