Pull manifold?
Old Oct 16, 2021 | 05:21 PM
NoVA_69_442's Avatar
Pull manifold?
Working on 442 this evening, came across this sitting where the manifold and cylinder heads meet, little puddle of oil. Stuck a napkin in there to soak it up and more to its place. Not sure what happened, been driving it around this summer no issue, and never seen this before. Not sure where the rtv went. So do i need to pull the manifold and reseal it?
Old Oct 16, 2021 | 05:26 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Try retorquing before resorting to pulling the intake.
Is it leaking anywhere else?
Old Oct 16, 2021 | 05:36 PM
Not leaking anywhere else. I can put my fingertip in there and feel a gap. I'll try retorqueing.
Old Oct 16, 2021 | 06:34 PM
Rallye469's Avatar
Ive heard of guys putting some sealant in with a syringe.
Personally, I’d dab it with a napkin every so often and not worry about it.
(but I’m lazy…and if a race car isn’t leaking oil…it means it’s out of oil)
-peter
Old Oct 16, 2021 | 06:48 PM
OLDSter Ralph's Avatar
I would suspect a valve cover leak. But it might not be that. If thats what you got after several months, it might not be worth pulling the intake manifold.
Old Oct 16, 2021 | 07:50 PM
I guess my concern was that under pressure oil would be shooting out of there. Would that not happen? Could i dry it up the best i could and shoot some rtv in there to try and seal it?
Old Oct 16, 2021 | 08:58 PM
gs72's Avatar
72Cutlass S
There is no high pressure oil in that area. You are either dealing with crankcase pressure pushing a little oil out past the gasket or as was mentioned a valve cover leak.
Old Oct 17, 2021 | 04:05 AM
fleming442's Avatar
-peter
^^^^this
Old Oct 19, 2021 | 11:55 AM
kencarr442's Avatar
Just make sure to clean the area really well with some brake or carb cleaner to degrease it first, or the RTV will never seal.
Old Oct 19, 2021 | 12:47 PM
I have had several 455 with aluminum manifolds collect oil there. I never figured out the problem. I would guess it’s coming from the valve cover.
kplange
Dec 12, 2016 06:14 PM
Skitch72
Jun 18, 2014 09:35 AM
805cut
May 11, 2012 11:09 AM
chris83
Nov 22, 2010 04:37 PM
Southern_Hospitality
Mar 7, 2008 10:26 PM
