Power Window Interchange?
Old Mar 26, 2014 | 02:21 AM
jensenracing77's Avatar
Are the back power window parts on a 70 Supreme the same as the hardtop?
Old Mar 26, 2014 | 03:02 AM
Dave Siltman's Avatar
I would say some are and some aren't. The obvious items such as the glass itself and probably the channels would not interchange, but the regulator, rollers, and some others might. Gee, Eric, I thought you would be the "Go-To" guy for this one! Your knowledge is light years ahead of most! I'm sure Scott will chime in and Joe P. will eventually tell us. Do you have a Hollander?
Old Mar 26, 2014 | 06:39 AM
66400's Avatar
Yes the the rear regulator is the same across the board for all 68-72 Abody 2 dr cars.
As to the rest of the hardware????????????
By the way for some reason Hollander does not list rear quarter regulator interchanges. Only front and rear door regulators.
Henry
Old Mar 26, 2014 | 06:46 AM
marxjunk's Avatar
regs work for convert too
Old Mar 26, 2014 | 07:53 AM
4speed455's Avatar
I have front and rear power windows from 72 Monte Carlo in my 70 Cutlass convertible. I used everything except the glass.
Old Mar 26, 2014 | 06:05 PM
Post
I have been looking at the parts book and now even more confused. I can't remember where to find want all the numbers mean in the parts book to tell what each car is. There is 3567, 3577, 3677, 6687, 4487, and on and on. what are the numbers for a 70 Cutlass convertible, hardtop, and Supreme?
Old Mar 26, 2014 | 06:15 PM
66-3X2 442's Avatar
Henry
I believe that post cars use different regulators than hardtop cars front & rear.
Old Mar 26, 2014 | 06:28 PM
Paladin31's Avatar
4467, 4487 (if you meant post coupe 4477) 4257 in the order of your question
Old Mar 26, 2014 | 06:34 PM
66-3X2 442's Avatar
Don't quite follow you but what I'm saying is that 2 door post sedans use different regulators than 2 door hardtop cars use or maybe I'm wrong,am I?
Old Mar 26, 2014 | 06:39 PM
Mr Shifty Sidney's Avatar
Hope this helps, for 1970 models.
Don W
Old Mar 26, 2014 | 06:40 PM
Paladin31's Avatar
Quoteth
No no no...I was replying with my 1 finger typing style.. so same time as you posted...so I was answering Eric's question of model #'s. I agree with you.
Old Mar 26, 2014 | 06:45 PM
marxjunk's Avatar
post cars use diff regs..kinda...
on the front use 68 hardtop or elcamino regs..on the rear...really diff...really rare..but some guy is modifying hardtops to work in post cars
Old Mar 26, 2014 | 08:15 PM
tomsw31's Avatar
To further clarify, all 1968 to 1972 gm A body 2 door hardtop and convertible rear window regulators interchange whether they are power or manual. 4 door and post rear regulators are different. Front door regulators are the same on 1970 to 1970 2 door hardtop and convertible A bodies. So yes, the power window set up out of that SX will work on your W30 if that is what you are wondering.
Old Mar 26, 2014 | 09:39 PM
66400's Avatar
Yes you are right.
Henry
Old Mar 27, 2014 | 02:14 AM
I am not adding them to my W-30. I have another guy wanting me to install them in a car he wants to buy.
Thanks,
Old Mar 27, 2014 | 04:29 AM
MellowYellow's Avatar
Did you check the parts manual?
https://classicoldsmobile.com/forums...ts-manual.html
f-85
Jan 16, 2012 06:10 AM
jugdish
Aug 18, 2011 09:57 AM
2blu442
Feb 21, 2011 12:29 PM
Mister
Jan 2, 2008 08:26 PM
2blu442
Dec 18, 2007 06:06 AM
