Power steering help needed!
Old Mar 19, 2014 | 06:25 AM
mid-life-olds's Avatar
Eagerly awaiting some nice weather to cruise in, I was getting the car ready for spring. I started up the beast and heard some grinding noise coming from the power steering pump. I took it around the block and it was getting worse. By the time I could put it back in the driveway the p/s pump was smoking and smelly. I opened the lid and to my surprise the fluid had gotten so hot that it actually melted the plastic dipstick! It was also leaking from the compression fitting on the p/s line. So I am thinking that something in the pump is blocking the lines, because I also had no power steering on my short test run. Plan is to replace the pump and both lines while I am there. Anything else I need to look out for???
Thanks in advance for the advise!
Old Mar 19, 2014 | 08:11 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You are doing exactly what I would do if it were mine. After that there is only one part left.
Old Mar 19, 2014 | 08:56 AM
... Which you may want to upgrade to a '92-'97 (if I recall) Jeep Grand Cherokee box anyway, while you're there...
Old Mar 19, 2014 | 09:11 AM
442craig's Avatar
These guys make the conversion kit. Also rebuild pumps
http://lee-powersteering.com/
Old Mar 19, 2014 | 03:39 PM
4speed455's Avatar
X2 I just did this on my 70. It was cheaper and easier then rebuilding my original box. And a really sweet upgrade.
http://realoldspower.prophpbb.com/topic1558.html
Old Mar 19, 2014 | 06:21 PM
rjohnson442's Avatar
Mr. Johnson
Does it have to be a grand cherokee or will an XJ work as well(92-97) I'm at the point of a new box as well.
Old Mar 19, 2014 | 06:48 PM
XJ (regular Cherokee) will NOT work. It's a "tall" box, like on a Bronco.
Same is true for '99-up Grand Cherokees: Completely different box.
But the pre-'99 Grand Cherokee box is a Saginaw box, identical to the near-universal GM box.
Old Mar 19, 2014 | 08:37 PM
442craig's Avatar
I bought a remanufactured one at Pep Boys ("97) for $150, worked great. I had Lee Power steering put the stock Olds shaft in it so it would take a stock rag joint. The rag joint that came with the kit was too large in diameter.
Craig
nicks1966
Jan 12, 2014 01:46 PM
75cutty455
Jun 28, 2012 05:59 AM
cobalt
Jun 27, 2012 02:53 PM
cobalt
Jun 26, 2012 05:04 PM
xerxes600rr
Aug 30, 2011 06:43 AM
