Power steering brackets options
Old Dec 29, 2018 | 04:26 PM
Mcolabella's Avatar
I have a PS bracket from G body olds that I want to use on my 65 cutlass, I am looking for some photos of the stock setup can't remember the way it was mounted way back when I took them off.
Also going to be running taller covers so I like the idea of the pump sitting down lower any suggestions and photos would be great
Old Dec 29, 2018 | 05:14 PM
nicks1966's Avatar
the frame is 1 inch narrower than the late model cars so you are going to have to modify the lower bracket to get it to fit. I can't remember if the bracket hits the frame or the steering box
I had to do the same on my 66, I will see if I can find the picture I had or the modified bracket.
Old Dec 29, 2018 | 05:47 PM
Mcolabella's Avatar
thank you also considering modifying that ungodly looking back bracket or getting rid of it
Old Dec 30, 2018 | 02:26 PM
nicks1966's Avatar
I found two pictures one of the bracket and one looking at it installed just above the steering box, I believe I cut off 3/4 of an inch
jjokrm
Jan 14, 2026 06:46 PM
snotrocket71
Aug 4, 2018 11:48 AM
Cincinnati Rick
Dec 3, 2015 10:05 AM
nelsontj
Sep 5, 2015 07:21 AM
foo
Mar 2, 2014 04:54 AM
