Posi question?
Old Mar 4, 2016 | 01:53 PM
sammy's Avatar
Sammy70 455 Supreme
Posi question?
I have a 3.08 gear from a 1978 Camaro..posi unit. Anybody know if it will fit in in a rear from an 1985 442...8.5?
Thanks,
Ted
Old Mar 4, 2016 | 02:14 PM
Redog's Avatar
pretty sure it will, asumming the gear you have is also from a 8.5 GM rear
Old Mar 4, 2016 | 04:11 PM
Railguy's Avatar
Although I can't say for sure . I just put limited slip carrier and gears from a 85-86 grand national in 74 omega.
Railguy
Old Mar 4, 2016 | 04:21 PM
It should fit as both should be 8.5" 10 bolt rears. If you post the casting numbers on the posi carrier we can say for certain if it will fit or not.
Old Mar 4, 2016 | 04:27 PM
Octania's Avatar
85 442 is a 3.73:1 ratio, right?
Old Mar 4, 2016 | 04:42 PM
sammy's Avatar
Sammy70 455 Supreme
Yes
Old Mar 4, 2016 | 04:49 PM
sammy's Avatar
Sammy70 455 Supreme
3984829 13:40 GM. 6E
310 1978.....pinion
Casting...410408N......carrier
Old Mar 4, 2016 | 06:06 PM
Octania's Avatar
so the goal is to end up with a 3.73 posi?
or swap it all and have 3.08 posi?
Old Mar 4, 2016 | 06:33 PM
sammy's Avatar
Sammy70 455 Supreme
3.08
Old Mar 4, 2016 | 09:12 PM
410408 is the 3 series posi carrier so it should work with either the 3.08 or 3.73 gear set.
I would just put the posi in with the 3.73 gears as all that would be needed is setting the backlash instead of an entire ring and pinion gear installation. Plus I would prefer 3.73s over 3.08s, but that's just my preference.
Old Mar 5, 2016 | 07:21 AM
Octania's Avatar
Yeah, what he said
why lose the performance ratio?
I found this in the PN database
"You have the 8.5 inch "corporate" 10 bolt in your car, so you can use a limited slip diff from another 8.5" 10 bolt with no problems.
The 410408 is a 3-series carrier, for 2.73 & numerically higher ratios, and the 410409 is a 2-series carrier for 2.41/2.56 ratios.
This site gives the years and applications for a lot of vehicles with the 8.5" 10 bolt: http://www.richmondgear.com/01pdfs/page10.pdf -
Chevy & Chevelle 70-76; Chevy II 70-75; Camaro 70-81; Z28/TransAm 72-81; GTO/Firebird 70-81; Olds F85/Cutlass 70-76; K10/K20 Front 77-87; Blazer front 77-91; C10 K10 Blazer Rear, C1500 K1500 Rear 80-02; Suburban Rear 80-96; Suburban Front 77-91; G10 G20 Van 79-96; Elcamino 73-76.
"Posi Carrier numbers 410409 or 410408 for c-clip axles will work in your non-c-clip axle. '409 would need a ring gear spacer to use gears 2.73 and larger numerically. There are also carriers numbered 725 and 726 which are the non C-Clip application carriers which would work fine as well."
Old Mar 5, 2016 | 07:28 AM
sammy's Avatar
Sammy70 455 Supreme
Thanks for the input👍
I am taking your advice and sticking with the 3.73 gearing....
Old Mar 18, 2016 | 06:18 PM
Ted, here are some pics of the 410408 Series 3 that I put into my 72. I opted for 3.42:1 gearing. This came to me from Jim Mitschke (aka Monzaz). If you need any help setting it up, he's your go to guy.
Bearings pressed, ready to install
Casting part number
Just as it should be - 10 bolt
Old Mar 18, 2016 | 08:11 PM
tru-blue 442's Avatar
Old School Olds
Welcome back Allan! You have been missed. Hope to see more posts from you, A.
Old Mar 18, 2016 | 08:23 PM
sammy's Avatar
Sammy70 455 Supreme
Everything Adam said! Good to hear from you Allan👍
nj_cutlass72
Nov 20, 2019 09:11 PM
jensenracing77
Drivetrain/Differentials
15
Feb 24, 2010 02:35 AM
69OldsCutlassS
Sep 9, 2009 01:05 PM
jensenracing77
Jul 11, 2009 11:02 AM
buzzbomb
Jan 6, 2008 09:51 PM
