Posi or ltd slip
Posi or ltd slip
I have a 69 Cutlass with a 3.23 rear. When up in the air and the wheels are turned they both go the same direction. I had figured it was a posi rear but when I leave a trail of rubber on the road it is just the DS. This would make me think it's a limited slip rear. Is there a way to know for sure. I assume a posi would leave two trails of rubber I assume.
Steve
Steve
Steve
Steve
As said, posi-traction and limited slip are the same thing just different marketing names.
An open diff can have both wheels turn the same direction when checked as you did, it just depends upon how much friction there is at the wheels. If the wheels can "freewheel" very easily and the gear mesh inside the diff has more friction than the wheels have, then the wheels turn instead of the gears in the diff turning. Try again but have someone put a hand on one wheel to see if it continues to try to turn or if it can be stopped very easily.
This could still be a limited slip diff with severely worn clutches, so as said pulling the cover is the sure way to determine what's in there.
If you lift one tire off the ground w/ the trans in neutral (parking brake released), it should take > 100 ft-lbs of torque to turn that tire if the posi / LSD is working correctly. If it spins easily (<20 ft-lbs), you likely have an open rear. In between its a worn out posi.
Usually the passenger side tire is the one that goes up in smoke. If you put air bags in the rear springs and isolate the air lines side to side you can adjust preload to where the “peg-leg” will spin both tires.
Having said that, the only way to be sure is to remove the diff cover and inspect things. The carrier could be worn, and need rebuilt
Okay, so I lifted the PS side put it in neutral and started to torque the lug nut, gradually increasing to 100# no slip, did the same on the other side, 100# no movement. Hum, I checked the tire pressure, 35 on the DS and 25 on the PS side. Equaled them out and had to wait for a dry day and took it out, found a quiet private place and punched it. Two nice trails of rubber!!!!! Yay, what a relief. I had just checked the tires a month or so back so I will need to stay on top of it. Thanks to all for the suggestions.
Steve
Steve
Look for the two-letter code on the passenger side axle housing. If you have the "O" type differential, and unless someone has completely changed out the gearing, you should be able to find a two-letter code of "SF" (drum brakes) or S7 (disc brakes) with anti-spin. The two-letter code is usually facing directly forward or directly aft on that passenger side axle housing. It might be upside down and buried under years of dirt, grime and perhaps some rust, but you should be able to find it.
Randy C.
Randy C.
So I cleaned up the PS axel and could not find any #s. It is a 3.23 Posi rear for sure. Would those #s on it confirm if it is an Olds rear and possibly original? A PO did many performance improvements so I'm not sure if it is even an Olds rear. Any help is appreciated.
Steve
That's a Pontiac 10 bolt rear end according to monzaz on the JD Race forum:
http://forum.jdrace.com/viewtopic.php?t=500
According to monzaz in the link I posted above it's a strong rear and the brakes are the same:
Post by monzaz » Mon Apr 24, 2017 8:19 pm
oK YOU HAVE A 1969 Pontiac 10 bolt 8.2 rear end
Axles are 28 spline bolt in - it is not original to the Chevelle BUT can be a very good candidate for better power in a 10 bolt rear.
the date is September 18 1969 housing (I 18 9 ) was not a (I188) ity is Letter I (month) and number 18 DAY and Year 9
gear ratio is a 2.56 freeway flyer gear NON POSI
You can fit any ratio you want in the rear ...NEW posi and 3.55 gears will fit right in.
We sell all the parts for it or you can go else where too.
Axle bearings will be seal and bolt in from the housing end flanges.
This rear will take the same brakes as your 12 or 10 bolt Chevelle rear also. 9.5 x 2
U-joint will be slightly bigger than a Chevy also again more strength. ALL Buick Olds and Pontiacs got bigger yokes than the Chevys.
It's a direct fit so if the car originally had say a 2.56 rear, then it would be an easy way to get a much better rear gear and posi.
As far as being common, that would depend upon what was available in a given area at a given time over the past 50 years. The rearends are interchangeable between all 68-72 A-bodies, which would be any of the vehicles below:
Buick Skylark, Gran Sport
Chevrolet Chevelle, Malibu, Monte Carlo, El Camino
Oldsmobile Cutlass, 442, F-85
Pontiac LeMans, Tempest, GTO, Gran Prix
No, not quite. A locking differential, whether it is activated by an electrical solenoid, by cables, by pressurized air, or by inertia, creates a solid mechanical lockup between the axle shafts. There is no differential action and both tires will turn the same amount, even if one is off the ground. This is why there is a caution that it is not to be used on dry pavement.
