Ported or manifold vacuum advance?
Old Mar 18, 2017 | 03:54 PM
76olds's Avatar
Hookers under Hood
I've been reading a few articles about this and it seems that manifold vacuum is the best way to go for a non emission set-up.
I'd like to do a Poll but forget how.
What do you run Ported or Manifold Vacuum Advance ?
Old Mar 18, 2017 | 04:27 PM
Imho, there is more to it than that. Its not just a matter of choosing one over the other, its the total pkg.
The questions are:
Is your year engine stock and is it equipped with a temperature activated switch and your running stock settings on a stock engine?
Do you run an HEI in place of a stock points distributor and max'd out the timing curve. Did you limit the vacuum advance to compensate for the curve change?
Do you run an aggressive cam and higher than stock compression, where you need the extra advance to make the idle smoother and control the extra heat?
Do you live in California?
With stock engines to be honest it really doesn't make much difference if your running stock timing settings.
To answer your question I'm running manifold, vacuum can limited to 12*.
Old Mar 18, 2017 | 04:46 PM
don71's Avatar
same but different
I'm using ported. Pretty much always have but it doesn't hurt to experiment.
Try manifold and adjust what ever settings you need to.
If you don't like it, go back to your existing settings. That is assuming you record them before you....open up too much of those Canadian spirits.
Old Mar 18, 2017 | 05:24 PM
76olds's Avatar
Hookers under Hood
This is what I read, I'm sure most already know this stuff, but I'm just looking to learn a few things . The LAST PARAGRAPH is what got me thinking.
Ported Vacuum vs. Manifold Vacuum
I found this article while searching for good tech information on the comparison of ported vacuum versus manifold vacuum. I don't know the author so I can't give valid credit. ChevelleStuff.Net doesn't indorse either method and there is a lot of discussion as to which is better. So, I'll present the article and you, the reader, decide.
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whiz-bang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, drivability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Old Mar 18, 2017 | 06:32 PM
At the end of that article it lists a bunch of vacuum advance unit part #'s based on how much timing they provide vs the amount of vacuum it takes for them to operate.
Old Mar 19, 2017 | 08:20 AM
Same here.
I made an adjustable stop for the vacuum advance so I can set it whatever I want.
Old Mar 19, 2017 | 02:37 PM
76olds's Avatar
Hookers under Hood
I was thinking to put my adjustable vacuum can to 10-12 using manifold and adjust my timing to where it will be happy. I'm new to this type of tuning, setting my timing by ear is getting difficult with headers and duals .
Eric
Old Mar 19, 2017 | 02:53 PM
How long does it take to set timing by ear compared to hooking up a timing light? Not to mention with a timing light its 100% repeatable and accurate.
Old Mar 19, 2017 | 03:16 PM
76olds's Avatar
Hookers under Hood
Its not that it would take to long, well..... for me its a matter of not being that experienced with a timing light/ vacuum can and tuning myself, but I want to give it a shot and see if I can do it . Also my timing is so far advanced that the timing marks are no longer useful.
I hope the dial back timing light will help me with this after I take the car out of storage.
I bought the summit dial back timing light last year but didn't use it LOL. I've bought lots of tools that I hope to start to use as I get older and have a bit more time on my hands.
Old Mar 19, 2017 | 03:37 PM
Lol, more time? The dial back timing light is simple to hook up and use, you'll wonder why it took so long to buy one. Once you get your timing set, write it down somewhere.
Old Mar 20, 2017 | 09:12 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
12-14* base timing at warm curb idle. Manifold, not ported vacuum. A vac advance canister with a travel limit set to 8-10*. Use an adjustable travel, not adjustable rate canister. So now at idle, you have 20-22*. Have the centrifugal brought all-in before 3000 RPMs for a total of 36-40* at 27-3000RPM. This is a good starting point for most Olds 330 350 400 425 & 455s in stock or mild cammed engines. At least this has been my experience over the last 35 years.
This spec applies to at or near sea level, 91-92 octane or better gas, 10.5 to 11.0:1 comp ratio max. Adjust according to your ambient conditions.
Give the car as much total advance as it will handle without detonation. Of course, make sure to dial in the A/F ratio. Use a setback timing light to get it close then use a vac gauge to super tune. You're looking for the highest possible vac reading at idle. Go back n forth between the timing and A/F until its where you like it. You can use two different springs in the centrifugal advance to tune the rate at which it comes in. You'll be rewarded with burnouts and smooth acceleration.
Old Apr 21, 2019 | 06:04 PM
poss's Avatar
manifold
Manifold with a performance Cam. Idle quality is much better with 20-22 degrees. Like said above must set up dist to the specs!
craig442
Oct 16, 2017 01:47 PM
sqeeek
Feb 26, 2014 02:35 PM
oldsbucket
Jul 14, 2013 08:22 AM
mlouderback
Mar 23, 2011 05:42 PM
88 coupe
Jul 31, 2008 08:54 AM
