poly strip discs
Old Apr 13, 2015 | 08:15 PM
ryneves's Avatar
poly strip discs
So I bought these 2-4.5" poly strip discs from home depot to try out on my floor pans. I was using a wire wheel to strip paint and rust so I can cut out and weld in patch panels in my floorboards. The wire wheels were taking forever to clean with. It seemed that it would smear the old paint and seam sealer and take forever to clean a small area. So I bought a couple of these poly strip discs and man oh man! Those things work awesome! Only problem is they cost 10 bucks a piece and last about 3 mins. Is my grinder too high of an rpm for these discs or have other guys had the same issues? I'm thinking about buying about 10 of them to strip my whole floorboard after I'm done welding and using a flapdisc on the welds. Those things work sweet. I just wish they lasted a little longer. You probably get about 3 square feet per disc and bam! It's toast. My grinder is a Dewalt 4.5" grinder at 11000 rpm. Maybe it's too much for em. Anyone else try these?
Old Apr 14, 2015 | 04:56 AM
cherokeepeople's Avatar
do you have an air compressor?if so they make small spot sandblasters your not setting there blasting away so air usage is pretty low a pancake compressor would work.
Old Apr 14, 2015 | 08:38 AM
RROLDSX's Avatar
They are considerably cheaper at HF especially when on sale.
Old Apr 14, 2015 | 08:58 AM
Tom442's Avatar
These work well for paint also.
I've used them.
http://3mcollision.com/products/abra...ch-coarse.html
Old Apr 14, 2015 | 09:43 AM
Those are cool. I've never seen them before.
Here's a more detailed link.
onofre442
Sep 10, 2013 02:24 AM
Mark71
Jul 17, 2011 06:51 PM
getawaycar
May 19, 2011 11:38 PM
RAMBOW
Mar 16, 2011 03:56 PM
steve walker
Suspension & Handling
Nov 17, 2009 05:34 AM
