Plugs ?
Old Jan 21, 2022 | 09:52 PM
jerbear2's Avatar
Plugs ?
Have a 394 with 2 BL carb. Need to know what AC DELCO plugs # to put in it. 1962 Olds 88 .
Old Jan 22, 2022 | 12:09 AM
Ozzie's Avatar
My books show:
High compression: AC 44
Low compression: AC 45
The gap in either case is 0.030"
Torque: 35 ft.-pounds
Old Jan 22, 2022 | 12:14 AM
69CSHC's Avatar
AC 45 gapped to .030 according to Carnut.com which I trust.
http://www.carnut.com/specs/gen/olds60.html
AC R43S according to Fusick Olds which I both trust and have pleasantly dealt with.
http://www.fusickautomotiveproducts....s.asp?dept=703
Why the difference ? My guess is the R43S is the modern more readily available equivalent. As it does make the Carnut list but only as early as 1969 ...
I would still verify before proceeding.
Old Jan 22, 2022 | 01:30 AM
fleming442's Avatar
The compression makes the difference. The lower the number, the colder the plug (unless NGK, they're the other way). A hot plug in a high compression engine will likely have detonation problems.
Old Jan 22, 2022 | 06:48 AM
rocketraider's Avatar
Oldsdruid
Use the 45 or other brand equivalent. If you get detonation on 93 octane then use the 44. The 43 is a cold plug which likely won't burn off deposits in normal driving.
There's a tech bulletin from 1965 addressing this. Recommends use of the 43 only in Starfire 394 engines regularly seeing high speed or hard acceleration service. Course there was 100 octane leaded fuel available back then too.
Old Jan 22, 2022 | 09:05 AM
Tedd Thompson's Avatar
What color is the block? IF red it should be the hi compression engine, if turquoise it is probably the low compression. Either one could be had with a 2 bbl...Tedd
Bfg
Sep 21, 2015 10:07 AM
63super88
Jun 23, 2014 06:03 AM
brandon 455
Jul 8, 2013 07:08 PM
196798
Feb 20, 2011 09:21 PM
KQQLCAT
May 6, 2008 08:18 PM
