Pickup: 4wd or 2wd?
Old Dec 29, 2014 | 10:50 AM
Tom Bilse's Avatar
Pickup: 4wd or 2wd?
My wife and I are in the process of replacing our '00 Xterra (190K mi).
I'm strongly leaning toward a crew cab mid-size pickup.
I'd like to get CO members' preference between 4wd and 2wd. Is the price difference for 4wd worth it?
Though we live in a relatively flat terrain area in N. Texas, we plan to keep the vehicle for a while and may need 4wd for "just in case" situations.
Thanks for any input.
Seasons Greetings!
Old Dec 29, 2014 | 11:10 AM
I sent your a pm. As far as the 2wd vs 4wd, if you have a use for 4wd then I'd run with that. Also a 4wd in Texas is always going to bring more resale as thats the desired truck here in Texas.
Old Dec 29, 2014 | 12:04 PM
RandyS's Avatar
Lived in Texas for several years, had to use 4wd more than once. I would never own any type of truck that wasn't 4wd.
Old Dec 29, 2014 | 12:27 PM
oldsmobiledave's Avatar
Fyi
2wd trucks rapidly depreciate in value vs the same truck equipped with 4wd.
Old Dec 29, 2014 | 04:36 PM
Olds_71_442's Avatar
Your second sentence is a comment I've made many times over the years. I won't own a 2WD truck.
Old Dec 29, 2014 | 05:06 PM
m371961's Avatar
After owning and driving 2 wheel drive pickups for 30 years in all weather, I got my first 4x4. After that one I will never buy a 2 wheel drive pickup again.
But if you want better fuel economy, never go off hardtop, no snow, no boat ramps, and don't care about re-sale, then get a 2 wheeler.
Get stuck once, and you will regret it. And if you ever tow anything heavy you will like low range. The ability to back up a trailer at or just above idle is handy.
Old Dec 29, 2014 | 05:12 PM
Oldsmaniac's Avatar
Some good points brought up. In central NJ we get snow, sometimes a little and rarely a big dumper. When I bought my truck in 05 at the age of 50 I asked myself was there ever a situation I was in that I needed a 4wd. The answer was no. Second question was will I go off road with it, the answer was no. Thirdly do I want to spend the xtra cash for something I dont need and something that will give less gas mileage, the answer was no. Lastly I keep my vehicles forever so resale vale was not a point.
Old Dec 29, 2014 | 05:13 PM
1970cs's Avatar
Lansing built
I have had a lot more two wheel drive trucks than 4wd, FYI my first 4wd has just been purchased in the last few days.
The 4X4 is for my wife, I can handle 2wd trucks up here in Michigan. Must be weighted with a couple hundred pounds over the rear wheels and tire pressures lowered to 32 PSI.
I will agree with the rest that 4wd retain their values better!
Pat
Old Dec 29, 2014 | 07:52 PM
oldolds88's Avatar
bought a 2011 gmc ext cab 1500 4x4 to replace my 97 gmc 2wd,5.3 6spd auto, 19mpg hwy. 12 pulling the bass boat. i dont have any problem with getting the boat out of the water now. i vote 4x4
Old Dec 29, 2014 | 08:30 PM
As above, it depends on your planned use.
2WD (or part-time 4WD) will definitely give better gas mileage, and will be simpler to fix if you ever have a problem with the transmission or the dreaded transfer case.
4WD will pull you out of more situations.
That being said, my current truck is a 1990 GMC diesel 2WD ¾ ton, and I've driven it on and off through about six Maine winters (every day through one winter, as my other car needed a head gasket), and I never had a problem with traction. I do not drive off-road and did not need to launch any boats.
My wife and kid both have 4WD vehicles, and I will admit that it requires less skill to get theirs out of snow banks, but you can do fine in normal driving either way.
Old Dec 29, 2014 | 09:25 PM
orange442's Avatar
I have had many 2wd trucks and they would most of what I needed them to do but not everything I wanted to do. I personally kept running into situations where I needed 4wd. I do a lot of hauling cars and parts and many times I had to have help to retrieve a vehicle or just wait till a buddy could help. I have also almost tore up my 2wd trucks trying to get unstuck, whether it be mud or snow. When I bought my 02 GMC Duramax in Dec. 01, I bought a 4x4 because I planned on keeping it for a very long time so I wanted it to be able to do just about anything I would ever need it to do. It has 46k miles on it. I daily drive a 93 Chevy 3/4 ton 4x4. I have had to use the 4wd several times so it comes in very handy. They do have a little higher maintenance cost if you need to work on the 4wd specific components but it is worth it to me. Also, one bad thing about owning 4x4's is you are the guy your buddy's call when they get stuck and need to be pulled out.
Old Dec 30, 2014 | 03:26 AM
FMB42's Avatar
If you're divided between 2x and 4x than I'd go with a 4x.
And owning any truck makes you the "go to guy" when your non-truck owning friends need to haul something or move.
Old Dec 30, 2014 | 05:37 AM
I haven't been w/o a 4X4 in years love them
Old Dec 30, 2014 | 05:49 AM
RetroRanger's Avatar
72 Olds CS
A guy I work w sold his truck and bought a jeep, he missed the hauling capacity of the truck so he bought a trailer. Now he lends out the trailer instead of the truck!
Old Dec 30, 2014 | 06:13 AM
cutlassjoe's Avatar
Back in 08' I bought my wife her jeep Liberty. She says she will never drive a car again. Now she has her eye on a 2013 jeep Grand Cherokee.....Yikes. After driving the jeep in the snow my next vehicle will be a 4x4 truck, suv for sure.
Old Dec 30, 2014 | 06:46 AM
F-85 4-4-2's Avatar
I also have a '90 Sierra 2WD. It has seen snow service, but no more. Gets low 20's MPG, no complaints.
BECOTruck4-Oct-2009.jpg?1419950397436http://i777.photobucket.com/albums/y...?1419950397436
Old Dec 30, 2014 | 08:41 AM
66luvr's Avatar
4X4 for me. I have had occasion to tow sometimes, cars mostly. I have been in a few situations while towing a car on a trailer when I would not have accomplished my goal without being able to put my truck in four wheel drive. Then there is the ease of using it in the snow, and visiting rural areas for various reasons, I would like to always have a 4X4. Not saying I would not own a 2X4 truck possibly, as long as I also have a 4X4.
Yes, I've been stuck in deep snow with a 4X4 (no posi), so I highly recommend posi, or whatever your brand of truck calls it, for the rear, plus if there is some similar option for the front and I had a choice I would have that also.
Old Dec 30, 2014 | 08:52 AM
When I lived in SoCal, my 2WD Chevy crewcab was fine. I never needed 4WD. Here in NoVA, I live on a farm with a dirt road that rarely gets plowed in winter. I use the 4WD (between the occasional snow and driving in the mud on the farm). Depends on what you need. The 4WD will be more expensive to purchase, operate, and maintain. For example, the front rotors on my 99 Chevy K3500 crewcab dually are behind the hubs. 2WD versions are not. Changing or turning the rotors is a royal PITA. Also, it doesn't matter if it's part time 4wd or not - you will still be dragging all that extra weight around in 2WD mode. And just try changing the trans with a 4WD truck - you've got to remove twice as many driveshafts and the transfer case first. If you don't need it, don't get it. If you do need it, get it.
Old Dec 30, 2014 | 10:38 AM
That's the setup I have - 4WD Jeep Wrangler and a 5x8 utility trailer.
Old Dec 30, 2014 | 10:43 AM
Tom Bilse's Avatar
Thanks for all the responses.
Regarding make/model, I've had a lot of interest in the new GMC Canyon. Though it's a mid-size, it's too long to comfortably fit in our garage (with the few other needed items in front of it - mower, etc.).
Contrary to popular belief, everything in Texas is NOT bigger, most notably our garage.
I'm now interested in the Nissan Frontier, which is shorter (though not by a bunch). Though the current version is somewhat dated, it appears to have a pretty good rep.
Thanks again. Happy New Year!
Old Dec 30, 2014 | 04:42 PM
m371961's Avatar
Up here in the rust belt I am waiting to see how the 2015 Ford aluminum trucks are gonna be.
The old Nissans were tough. We beat on one as a woods truck. And when you get a vehicle that hasn't changed much in the past few years a lot of the bugs in design have been worked out.
Old Dec 30, 2014 | 05:35 PM
Well said, Joe.
Old Dec 30, 2014 | 05:47 PM
Not a truck
A Nissan Frontier? I thought this thread was about buying a truck!
Old Dec 30, 2014 | 08:13 PM
cherokeepeople's Avatar
Well said, Joe.
yep have to agree i have basically lived on the roads here in iowa for the last 20 yrs.50k a year i started with an 84 chevy 1/2 ton 2wd 6.2 diesel pickup then a cadillac then a 2000 vw tdi.and i have yet to get stuck.one thing my dad used to say "with a 4wd your twice as far from the tractor when you get stuck"
Old Dec 31, 2014 | 04:13 PM
chip-powell's Avatar
4x4 every time and twice on Sunday
Old Dec 31, 2014 | 04:45 PM
Run to Rund's Avatar
I chose a Ram 3500 single wheel 4x4, Cummins, Aisin transmission. With the prices today, I wanted to get a truck that would do anything I needed it to do sometime in the future.
Old Dec 31, 2014 | 04:46 PM
4wd
I work in the Oil Patch in Western Canada. If you do not have 4WD you do not have a truck. Without 4WD you can not reach the places we drill wells.
Old Dec 31, 2014 | 05:09 PM
Funny story I had a guy looking for what he said a sturdy well built truck, we couldn't agree on price and he left. He comes back a few weeks later all proud to show off his new truck, a Honda Ridgeline. He goes on and on about how great it is and he wanted to show is what a real truck looked like. After he was done I lifted the door of the little compartment in the bed that looks like you can carry about 5 cases of beer in it. It even hade a drain. I picked up my mobile and acted like I was talking to someone, then pointed to the phone and said the country club up the street wanted their motorized beer chest back.
Old Dec 31, 2014 | 05:33 PM
Which, while completely true, is entirely irrelevant to the driver who lives in a city or a suburb, rather than an oil field, and never drives off-road.
I've said it in previous threads and I'll say it again, if you HAVE to get a 2wd truck, it better be a mid '70's International Harvester. It's the best truck ever made...period.
If you are looking for new, it depends on what you are using it for. Nowadays trucks are more status symbol that actual work vehicle. What will you be using it for? What are the roads like where you live? Is gas mileage an issue? Prices are down right now, but you know that that can not last.
If you are looking at imports, Toyota's traditionally have been the best bet. However, my Mother deals with the lemon laws and handles "buy backs" on recalled cars and trucks. She has told me about a very quiet recall on Toyota trucks from 2000-2010. The frames have been rusting out. Nissan trucks have never been very good for work (but I bet that they are great for going back and forth to soccer practice).
Old Dec 31, 2014 | 05:42 PM
  #31
Then...
Then a truck is not needed.
Old Dec 31, 2014 | 06:20 PM
  #32
Not necessarily.
A truck is for transporting more, larger, or heavier items than you can fit in a car.
You may need to transport lots of junk, whether motorcycles, or job materials, or tools and equipment, or to tow, but not off-road, in which case a 2WD is fine.
For instance, a businessman who needs to deliver bulky items to customers in town would be a fool to spend the extra money, and extra maintenance, on a 4WD pickup instead of buying a 2WD delivery van.
Alternatively, you may live or work on a facsimile of Verdun, but if you don't need to carry a lot of stuff a CJ-5 may be just fine.
Old Dec 31, 2014 | 08:35 PM
  #33
There is no correct answer to this age old question, personal preference and depth of wallet usually play a big part in the 2wd vs 4wd conundrum. I've been though all the different truck scenarios over the years an now I waste my money on old cars.
My biggest problem is I won't spend $40, 50, 60k on something I can't live in.
Old Dec 31, 2014 | 08:52 PM
  #34
Price
I wish it was only $60k. I looked at a new RAM 3500 dually the other day and the MSRP was only a few bucks short of $90k
Old Jan 1, 2015 | 03:25 AM
  #35
Ranzan's Avatar
Getting There
Like Dave I was checking out the new F350 last week with a price tag of just shy of 90K fully loaded.. asked the sales guy what a base model goes for and he said mid to high 50s
decided to keep my current truck for the next decade lol
Old Jan 1, 2015 | 06:27 AM
  #36
rustyroger's Avatar
'87 Delta 88 Royale
A friend lives in Texas hill country, he runs a construction business and hauls horse trailers to Team Penning meets. He tells me 2WD is all he needs, never got stuck ever.
However when he lived in Missouri 4WD was the only way to get mobile in winter.
What isn't there won't go wrong is a good engineering cliche, like a front diff and transfer case for example.
But get this - the much revered and respected on this forum publication "Consumer Reports" reckoned 4WD trucks had the edge on 2WD for reliability and breakdowns last time I read a copy. Go figure .
Roger.
Old Jan 1, 2015 | 06:42 AM
  #37
In Texas, a 2wd diesel truck is virtually sale proof on the pre-owned market. Trucks outsell cars 3-1. People here use them as family haulers. Most go for the 4x4 1/2 ton as there is not much difference in the price and they like the look better over functionality. Also there is not much difference in fuel economy between a 2wd and 4wd truck. Any gas powered truck will generally provide 250k miles and any diesel 500k miles easily. Most get tired of it and opt for a new truck at just under 100k.
Old Jan 1, 2015 | 09:09 AM
  #38
w-30dreamin's Avatar
71 & 72,now I want a 68
Do they still make 2wd trucks? just kidding,but they are more difficult to find.
My first truck was 2wd,didn't work out for winter in the snow,I slid all over the place,was scary at times. My second was 4wd and I fell in love,handles the snow great,no more scary rides. On my third truck and it's 4wd,I would not go back to 2wd.
Off the main roads where i live we don't get snow plows till mid morning,I have to be to work early morning,without 4x4 I would not make it to work when it snows.
Old Jan 1, 2015 | 03:39 PM
  #39
66 Olznut's Avatar
Ca's Only Official OLZNUT
Out here in Sunny So Cal, where it never snows, I've owned both 4x4 and 2wd. Only used the 4x4 for fun, never for anything work related, my current truck is a 2wd, the only problems I've had were with the 4x4 parts, axle seals, transfer cases.
Old Jan 2, 2015 | 04:35 AM
  #40
71rocket's Avatar
car nut farmer
Hands down, 4x4 p/u if it's going to see any adverse driving conditions, especially if you live in the country. I farm/ranch in SE Kansas and have to operate in the snow and ice on a yearly basis. When making a turn it's nice to have the front end lead the way, can make it up a hill, can get out of a slick spot. Personally, my life would be more difficult without four wheel drive. Depends on a persons needs. imho.
Had freezing rain yesterday afternoon and will be using it this morning.
