Panel replacement ??
Old Dec 10, 2016 | 10:10 AM
Zr1bandit's Avatar
Anybody ever replace the panel directly behind the rear window on a 1970 holiday coupe, what is it called and was it a big job to do ?? thanks Greg
Old Dec 10, 2016 | 12:27 PM
I did that on my '70 Supreme back in the 80s due to rust under the vinyl top. I welded in an entire section from a donor car. Removed the rear glass, cut out the entire panel and the window channel, and welded the replacement panel in.
Old Dec 12, 2016 | 03:08 AM
chopolds's Avatar
Not terribly difficult to do, if you have the tools to cut and weld. Was a lot harder making one from scratch, I did one for a 66 Lemans, when they weren't reproduced.
Old Dec 12, 2016 | 03:26 AM
Zr1bandit's Avatar
Anybody know where i can find this panel. What would it be called ???
Old Dec 12, 2016 | 04:27 AM
kad36's Avatar
Panel replacement?
It is called a "sail panel" Good luck! kad36
Old Dec 12, 2016 | 04:28 AM
Ranzan's Avatar
Getting There
it is called a tulip panel
I replaced mine on my 67
it wasn't to bad
Old Dec 15, 2016 | 11:01 AM
Zr1bandit's Avatar
This is the same panel im talking about. Is it available after market ???IMG_0391.PNG
Old Dec 16, 2016 | 02:38 AM
chopolds's Avatar
Simple search:
https://www.millsupply.com/68-cutlas...69.php?p=34682
Old Dec 16, 2016 | 04:15 AM
Zr1bandit's Avatar
Originally Posted by chopolds
Dont think that is it. I need one for a holiday coupe. That piece looks a little different Not sure tho
Old Dec 17, 2016 | 06:37 AM
Gary M's Avatar
Research before you do any cutting
Look up from inside trunk for spot welds where that panel meets the quarter panels. There may be some overlap that you can reuse to spot weld the new panel to. Drill out the existing spot welds. You may not get the gutter part that goes across under the trunk lid ( weather strip for trunk mounts to it) with the new panel so may need to reuse the existing one. May be spot welds there too.
steverw
Oct 1, 2014 08:02 PM
Eddie Hansen
Body work
26
Aug 13, 2012 08:41 AM
joe_padavano
Body work
Jul 26, 2012 02:13 PM
meoff
Body work
Aug 21, 2009 04:49 PM
Sturgeon
Oct 5, 2007 05:54 AM
