Oversize?
Old Mar 14, 2014 | 08:14 PM
wabasto's Avatar
Oversize?
hi all. i need a little help here. i have a 69 ragtop 4 spd car. i decided to freshen up the engine a bit. i last touched it 35 years ago. my question is, a machinist looked at the bore and found wear to be .005-.007 . all cylinders look ok. i had a few broken top rings and some pounded top ring lands. virtually no ridge on top and no marks in the bore. my question is where can i find a 0010 oversize piston set or can this engine just take a standard set of pistons and work ok? it is a 350 rocket.
Old Mar 14, 2014 | 08:19 PM
coppercutlass's Avatar
Chevy budget Olds powered
The cost to bore won't be much more than to hone if that's what you are getting at. I would just got .030 over. Of course this will be going to a forged set and it will need to be blanced and all that good stuff. I would go forged pistons vs. The stock cast style that are available. I spent 350 to bore and hone and install cam bearings and final clean.
Old Mar 14, 2014 | 08:26 PM
Yeah, you need pistons no matter what, since your lands are shot, so, unless you're going to do it The Copper Way™ and use a set of used pistons , you Might As Well have it bored and cleaned up.
(no offense, Copper )
Old Mar 14, 2014 | 08:37 PM
LOL . I have been known to use used parts lol. I don't think I have ever bought a brand spanking new set of pistons. Slightly used yes and some ancient and used lol.
80_cutlass
Feb 7, 2016 12:02 PM
chip-powell
Apr 9, 2015 02:08 PM
w-30dreamin
Oct 14, 2014 08:51 PM
rootney
Jul 31, 2013 05:40 PM
