options
Old Jul 19, 2014 | 12:17 PM
Tedisthebestkingintheworl's Avatar
options
Does anyone know if you could get a TH400 bolted to a ultra high compression 330 in a 1966 Cutlass as a factory option or would it have been added later?
Old Jul 19, 2014 | 12:25 PM
It would have been added, it wasn't available until '67, and then only behind the 400 in an A body.
Old Jul 19, 2014 | 12:40 PM
If it's a BOP T400 it will bolt up, but you'll have to relocate the transmission cross member back 6" and you'll need a new driveshaft. Unfortunately there are no holes drilled for the relocated xmember, but it's not hard to drill them unless you have a convertible. You will also need to modify or replace the front ebrake cable system.
Jul 5, 2012 09:34 AM
bschubarg
Jun 14, 2006 09:26 AM
jccc
Mar 13, 2006 05:02 PM
west tenn. 1
May 5, 2004 04:16 PM
chkoo7
Aug 10, 2003 10:05 PM
