Olds Parts on Craigs List
Old Mar 16, 2009 | 02:08 AM
oldsonharmont's Avatar
I Saw this on Craigs list and thought I'd pass it along. Good Luck!
Clearing out the garage and shed! Best offer on all prices.
OLDSMOBILE
1968 455, longblock, C heads, 4bbl intake, 130K miles, high compression, ran when pulled in 1985, stored indoors. $700
1968 455, longblock, C heads, 4bbl intake, RARE FORGED CRANKSHAFT! Ran when pulled. $1500
1969 350 #5 heads, virgin, 98K miles. $150
1969 Jetaway (Powerglide) transmission, 98K miles on it. $40
1969 3-speed Saginaw manual transmission with linkage. $100
1969 350 4-barrel intake, bead blasted, ready to bolt on, $100
1969 350 2-barrel intake, with Rochester carb, no pitting, $30 (two available)
1970 350, shortblock, standard bore, 160K miles, does not turn. Good core. $50
1970 455 4-barrel W30 Aluminum Intake, $1000
1970 455 4bbl intake from a 442, no pits but greasy, $100.
1971 Set of rebuilt big-valve G heads (455), $200
1973 350, longblock, #8 heads, 2bbl intake, does not turn. Good core, $125
1973 455, had been in a boat, J heads, 4bbl factory intake, does not turn. Good core, $125.
1974 455, shortblock, standard bore, 50K miles I was told, turns freely, no ridge, has manual (stick) crank, $300.
Nodular 455 Manual (Stick) Crankshaft, needs 1st rod journal repair. $100
1968 455 FORGED Crankshaft, 10/10, fresh and ready to go. $1200
1968 455 FORGED Crankshaft, 10/10, spun main, should clean up 20/10. $1000
1969 350 Nodular Crankshaft, STD/STD. $75
1963 215 Crankshaft, 10/10. $75
1966 442 Trunk Lid, no trim, solid, no rust. $200
1966 442 Core Support, $100
1966 442 Core Support, slightly tweaked, repairable, $60
1966 442 Driver's fender, needs lower patch comes with damaged fender with good lower, $300
1966 442 Convertible windshield header trim, mint. $100
1966 442 Bucket seats, black $300/pair
1966 Cutlass 4bbl air cleaner, $40
1966 Cutlass Trunk 'OLDSMOBILE' Trim, no pits, mint. $80
1950 Dash Grille, no pitting, nice condition, $50
1950 Master Cylinder, needs rebuild, $25
1950 88 Front Bumper Guard, NOS!!, $75
1950-51 88 and 88A miscellaneous door glass and window vents, $50 for all
1963 215 Factory Valve Covers, $40
1963 215 Rods, Stock $40/set
1963 215 Oil Pan, $20
1963 215 Front Cover, $40
1963 215 Distributor, $20
1963 215 Olds Rocker Arm Shaft, $40
1967 W30 Factory Dual Point Distributor, 1111151, $400 firm
1967 Turbo-Hydramatic 400 (TH400) transmission, long shaft, complete, $50
1967-1968 Disc Brake Rotors (2-piece), original, turnable, $50/pair (2 pairs).
1968 Turbo-Hydramatic 400 (TH400) transmission, long shaft, complete, $50
1968 442 Air Cleaner, 4bbl, restored, very nice. $100
1968 455 Ambulance/hearse exhaust manifolds, unique pieces! $150/pair
1968 442 X Exhaust Manifold, $75
1968 Hurst/Olds Power Steering Box, completely rebuilt and detailed. $350
1968-72 GM A-Body (Chevelle, Lemans, GTO, Cutlass, 442, Skylark, GS) Trunk Floor, Goodmark, 1-piece, New, $120
1968-72 GM A-Body factory floorboard, cut from rear seat rise to front floor seam. No hump. $100
1968-72 Cutlass Firewall Heater Boxes, rust free, $20/each
1968-72 Cutlass Gas Tank, no leaks, nice condition. $40
1968-72 Cutlass Blue Bench Seat Headrests, pair, nice! $30
1968-69 Cutlass/442 Bumper Jack hook, $10
1968-69 Bench Seat Manual Shifter handle and ****, $40
1968-69 442 W/Z Exhaust Manifold set, $200/each (2 pair)
1969 Cutlass Air Cleaner, 4bbl, very nice. $50
1969 Cutlass/442 Dash Pads, black, 2 non-AC (no vents), 2 AC (vents), pad only, cracked, good cores. $20 each.
1969 Cutlass rear bumper (no cutouts), no rust core, $100
1969 Cutlass front bumper, no rust core, $100
1969 Cutlass Post Doors, rust free, straight, $300/pair
1969 Cutlass Post Doors, some bondo in lowers, $200/pair
1969 Cutlass Trunk Lid, rust free, $125
1969 Cutlass S/442 Hood, some small holes where 'Oldsmobile' emblem mounts, stripped. $75
1969 Cutlass/442 Driver side quarter panel, FULL, straight, some minor rust on trunk dropoff, $300
1969 Cutlass Supreme Driver side fender, needs lower patched, $150
1969 Cutlass S Driver side fender, needs lower patched, $125
1969 Cutlass S Passenger side fender, needs lower patched, $125
1969 Hurst/Olds (only) rear differential, 3.91 posi, SL code, RARE $2000
1970 Big car dual exhaust manifolds. Passenger side has block off, driver side has hump. Factory 4bbl dual exhaust units. No pits. $250.
1970 2bbl Rochester carb, $10
1971 Toronado exhaust manifold, passenger side, $20
1973-75 Cutlass/442/Monte Carlo/Skylark/GS Swivel Bucket Seats, driver seat needs base repair, track are fine. $SOLD/pair
Lots of Pulleys, $10-20 each.
New Set of .040 Over Cast 455 Pistons, dished, $100
New Set of .030 Over Cast 303 Pistons, 7 in the set, $75
Set of forged 455 rods, $60
Set of 455 Main Studs, Milodon, new, $50
Set of 455 Head Studs, Milodon, new, $100
Set of 455 Special Main Bolts and Factory windage trays, $80
Lots more Oldsmobile parts also, just ask. Seriously!
sale-hfpbz-1073711824@craigslist.org
Old May 30, 2009 | 05:24 PM
Liegekiller's Avatar
I need a transmition
I have a 1966 cutlass and I need to get rid of the 2 speed tranny that I have and get either a turbo 350 or turbo 400 to put in it's place. The engine is 330 CI and from what I have researched as long as this transmition will fit the 350 rocket it will fit the 330. Do you still have a TH400 for sale?
Please call me if you can
Russel Reiter
719-205-6610
Old May 31, 2009 | 01:15 AM
I found that posting on Craig's List for Phoenix, Arizona under auto parts.
Just search 'Olds parts' and you should find it. It's been on there a while, but the guy still has some stuff, his name is Karl. Good Luck!
Old Oct 23, 2010 | 02:09 PM
rroobble's Avatar
1969 post doors rust free
i know this is an old posting
just wondering if you still have the doors-if so would you ship
thanks
rob
Old Oct 23, 2010 | 07:33 PM
I originally posted that over a year ago, so you're probably out of luck.
(it was also not my posting, just something I found on Craigslist)
Old Apr 1, 2014 | 05:22 PM
70cutty's Avatar
Beer Connoisseur
You guys do realize that this thread is almost 5 years old and Russell probably don't even have the car anymore
Old Apr 1, 2014 | 06:30 PM
HonestDave's Avatar
Thanks for the tip. A man gets old and his brain starts to slip a bit, like a worn out tranny !!
Back to my dishes....
Old Apr 1, 2014 | 08:04 PM
70cutty's Avatar
Beer Connoisseur
Haha no problem man.
jensenracing77
May 10, 2009 06:53 AM
Eddie Hansen
Jan 29, 2009 05:20 PM
